1010 Engine Kit - Will 1020 Kit Fit?
Vermont John
11-15-2007 06:23:38
My 1010 will not start. Seems to have spark, but will not run. I"m thinking about using an engine kit from Yesterday"s Tractor to improve compression. However, they do not list a kit for a 1010, only a 1020. Mine is a relatively late 1010. Will the engine kit fit?
Vermont John
11-17-2007 14:41:50
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to Vermont John, 11-15-2007 06:23:38
Thanks for the advice everyone! I may have to rebuild the 1010, but now I can move it to the garage. Today I installed four Aldor spark plugs. They are touted to be "super plugs." I was skeptical, but thought I would give it a try. Well, THE DARNED THING STARTED!!!!! I am so amazed! So, I will put the high performance coil and electronic ignition. Also, I'm going to install a Katz tank-type engine heater as recommended by jdemaris. Believe me, it was nice bringing up firewood in that loader tonight, as opposed to other alternatives!
Dave Fisher
11-16-2007 08:51:01
You can try these guys they have some 1010 engine parts if you do need them. I am also in the process of rebuilding a 1963 1010 Gas.
They have electronis ignition setup for these little tractors that is suppose to make them start and run really well
hope this helps
Dave Fisher Link
Vermont John
11-16-2007 14:41:11
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to Dave Fisher, 11-16-2007 08:51:01
Thanks, Dave. I ordered an electronic ignition. I also ordered a set of Aldor spark plugs and a 40,000 volt coil. Right now, in cold weather, the tractor seems to want to start, but can"t quite do it. It would be nice to have it running while I order in the parts for an overall. There is some good advice below from JD about working with the original pistons.
Brian Bell
11-15-2007 12:17:51
Just as an FYI, see link below to search for parts from deere. They pistons are either 125 each or 145 each depending on which are in your tractor. Quite costly to say the least. This site does carry some 1010 parts...will definitely save you some $$.
jdemaris
11-15-2007 06:32:05
1010 engine - gas or diesel - has nothing in common with the 1020 engine. Also, to my knowledge, nobody - ever - offered an engine kit for a 1010. I worked as a Deere mechanic for several Deere dealerships since the late 1960s. Parts have to be bought piece by piece, and many are only available direct from Deere.
If you're concerned about compression - consider doing a good valve job and maybe - rebuilding the pistons with Hastings shims, honing, and re-ringing.
Vermont John
11-15-2007 07:50:03
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to jdemaris, 11-15-2007 06:32:05
Thanks jdemaris. You're right. I was getting ahead of myself there. If I'm going to take the head off, I may as well do the rings too. What are the shims you're referring to? Is that to account for wear in the ring grooves?
jdemaris
11-15-2007 10:15:50
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to Vermont John, 11-15-2007 07:50:03
When the pistons are worn, often it's just the top-ring grooves. When new pistons cost $30 apiece, it's not worth fixing old ones. But - now many parts for odd-ball engines are getting extremely expensive - fixing pistons is often a better way to go. 1010 pistons might be close to $100 each now, I haven't checked lately. You can cut the grooves to an oversize width, and put in new standard rings with repair shims. Hastings sells the shims. 1010 and 2010s use a sleeve-deck - which is all four sleeves stuck together in one unit. Cost around $700 - $800 for a new one - and soon they will be unavailable. A gas engine, due to its low compression-ratio is much more forgiving than a diesel. So, often with a 1010 gas - you pull the engine apart. Remove the sleeve deck and reseal with new o-rings and gasket - and just hone the cylinder walls unless it's really bad. Then install repaired pistons (if they were worn) with new rings. Might also install new rod and main bearings also. Do a valve job on the head - often just needing a regrinding and new stem-seals - and you wind up with a pretty good, budget "rebuild."
In regard to spark - that's a touchy subject with 1010s - and we had lots of trouble. 1010 needs a lot of spark energy - that's why Deere used the 6 volt coil from the older 420 tractors, and used it with 12 volts on the 1010. Original 1010s had a built-in resistor and cranking-bypass built into the ignition switch. There was lots of trouble with it and it was later updated to a different system.
Mike M
11-16-2007 09:32:13
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to jdemaris, 11-15-2007 10:15:50
My uncle must of been an early victom of that starting system. One mention of a 1010 and he goes off about what junk they were and how his would never start,bla,bla,bla they susposedly bought it new ? Was a loader backhoe too. I hadn't put alot of faith in his complaining before because he isn't one to keep his equipment tuned up the best of shape. Too bad he didn't have you to work on it back in the day.
Vermont John
11-15-2007 13:26:54
Thanks for that excellent explanation. Today, I put new plugs in it and managed to get it started, but it was not easy. I'm going to do a compression test. I just bought a tester. If I can pick your brain one last time, the service manual says compression on the 1010 is supposed to be 7.9:1. My research indicates that 7.9:1 indicates just over 100 p.s.i. or about 20 bar. Does that seem correct? Approximately what level of compression indicates a compression problem?
jdemaris
11-16-2007 05:24:47
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to Vermont John, 11-15-2007 13:26:54
With all plugs out - at cranking speed - and at least five cranks for each cylinder - approx. 200 RPM the pressure should be a minimum of 125 PSI.
Those specs are for a warmed up engine.
Vermont John
11-16-2007 09:03:07
 Re: 1010 Engine Kit - Will 1020 Kit Fit? in reply to jdemaris, 11-16-2007 05:24:47
Thanks, JD. I'm guessing from the sound if it that I will not have near that!
