'48 JD B Shut Down
C DC
11-15-2007 05:48:23
While I"m gathering parts for my power-trol, I"ll ask yet another question. -And thanks to all of you for your help, I really appreciate it.
I have looked at the manuals, and it seems I have the wrong "dash" sheet metal. My B is a gas only model, but the dash piece has a hole in the lower left corner, like where the fuel selector valve would go.
Also, it has electric start, but no key. (I know it starts by the foot button at the flywheel) Sometimes, even with the throttle all the way back, it will just idle on and on and on. There is no way to shut it down. I"ve been pulling the choke and flooding it out. Is it supposed to have a key switch?
Forgive me and remember, I am new to this! LOL!
Randy G.
11-15-2007 12:56:13
 Re: '48 JD B Shut Down in reply to C DC, 11-15-2007 05:48:23
CDC, we have a 40 B slant dash all fuel that has a pull button electric start and no key or shut down method. So we either choke it till it stops or shut the fuel off till it dies. Done it that way since 1940 when my Grandpa bought it new.
C DC
11-15-2007 13:13:02
 Re: '48 JD B Shut Down in reply to Randy G., 11-15-2007 12:56:13
Randy G, if you would, send me an email.
I have a cousin Randy G from the Binghamton, NY area.
Be funny if that was you!
P Browning
11-15-2007 13:09:43
NEVER - NEVER - NEVER use choke as a shutdown method for two cylinder JD Tractors! If all else fails, read the Operator's Manual. Gosh! (PatB)
John T
11-15-2007 12:18:31
In my opinion the best way to shut down is to idle them down and then turn the gas off (sediment bowl shut off or 3 way valve etc) and let them run out of gas PERIOD. However, a worn or leaky 3 way valve can leak and since most dont use fuel or distillate anymore (gas only) I dont like to ever turn my 3 way brass valve, so I have a sediment bowl shut off.....
Depending on the carb and its settings, some die if the throttle is pulled allll the way back, but I'd still use the method above
DO NOT shut down by choking, that washes protective oil n oil seal (for compression n restarting and to avoid dry metal to metal start up) coating off the rings n cylinder walls plus contributes to raw gas getting into the oil.
On some mags like a Wico X theres the kill switch stud/terminal which you can depress to kill the spark or else run a wire from that stud/terminal up to the dash to a push or key swtich which kills the spark when that wire gets switched to frame ground.
On the battery powered coil ignitions (Wico XB or Delco) they, of course, need an ignition On/Off switch to shut power off to the coil to kill them although you could still turn the gas off and DONT FORGET to then turn the key off.
John T
THE SMOOTHED DEERES
11-15-2007 10:47:09
You say you've looked at your manuals ? And you don't know how to shut the tractor off the way it should be ? I'm confused ? OM-R2006
C DC
11-15-2007 12:08:45
 Re: '48 JD B Shut Down in reply to THE SMOOTHED DEERES, 11-15-2007 10:47:09
I must have over-looked it. I saw a video where a guy just reached around the dash area and it shut right down, I assumed using a key, and mine has no key.
I"ll look thru the manual more closely.
Thanks for the tip.
Hayfarmer
11-15-2007 07:07:40
On my G I generally shut it down by turning off the fuel and letting it run out. The exception would be for a short time in the field. I didn't shut the fuel down one time and came back to 2 cylinders full of fuel. Imagine how much fuel a G cylinder will hold. It seems to start better if I just run it out of fuel.
jd40an
11-15-2007 06:37:18
The simplest way to stop it is simply to idle as slow as possible, hold the brakes, put in gear & kill it with the clutch. Of course, it's always wise to also shut off the fuel valve.
Mike M
11-15-2007 05:59:22
I'm thinking all the dashes had that hole. And only the real late B's had a key switch for the wico XB dist. or a delco changeover. You can hook one up to ground out a mag if you want to. Your carb. throttle plate could be worn out letting too much air by ? carb. could be an all fuel one ? Someone could of bent the stop pin forward not letting the throttle shaft go closed enough to stop ? And DO NOT stop them by the choke as this loads the cylinders full of raw gas. Just shut the gas off at the fuel bowl and it will soon stop.
C DC
11-15-2007 06:08:29
 Re: '48 JD B Shut Down in reply to Mike M, 11-15-2007 05:59:22
The buttery fly (throttle) bushing is worn, so I"m sure it is getting air that way. And the stop screw is bent.
I was just wonder about the switch and what was the proper way to shut it down.
Thanks Mike.
BushogPapa
11-15-2007 19:29:00
 Re: '48 JD B Shut Down in reply to C DC, 11-15-2007 06:08:29
Humm, I wonder why that bushing could be worn...hummm..?????..!! Let's see..on a JD 116W wire-tie Baler, the plunger cycles 52 times per minute... That means the Governors OPEN 52 times per minute, TOO..!! Sometimes, 6 strokes to a bale too..and I mean Tight bales..! I used to hear those exhaust barks (straight Pipe) every day, all summer long it seemed..! We custom baled a lot.. But, it seems those bushings are NOT worn bad on these "B"s... I wonder why..? They have never been re-built, I know..! I think the manual suggests adjusting the throttle stop, to allow the engine to quit, if you pull the throttle all the way back.. Nice thought..but we usually had to put it in 4th or 6th and stop it with the clutch and brakes. It is just a "Normal" operating procedure...!!!
Ron..
