Broken oil filter cast head on 520
Eldon (WA)
11-14-2007 16:53:46
I tore down my latest project, a 520 with a knock. One rod bearing spun, trying to track down oil pressure problem. Oil pump shaft and coupler were intact. I removed the oil pressure assembly and pumped oil back thru the pressurized lines with no resistance. It is coming out the top of the oil filter head. I can't see exactly where, but it feels like there is a rough slot next to the main boss on top. Has anyone had a casting fail like this? I guess it is time to take the block off so I can get a better look. Where can I find a replacement head?
gtx1967jewison
11-18-2007 21:35:40
 Re: Broken oil filter cast head on 520 in reply to Eldon (WA), 11-14-2007 16:53:46
MOST likely hard (read FROZEN) water is what happened to it.
F-I-T
11-14-2007 17:08:48
third party image
Typically that casting cracks if someone overtightens the nut on the stud retaining the filter cover. This can distort the top of the can, or crack the regulator body, or both. Is the stud for the filter "loose"?
Check a salvage yard like Sharp's as this part is pretty common and not often broken. I'd buy the top and the body, and lap them where they meet to check that they are not warped from time. It's a cheap and easy check.
Frank
Eldon (WA)
11-14-2007 18:52:37
 Re: Broken oil filter cast head on 520 in reply to F-I-T, 11-14-2007 17:08:48
Thanks for the info.....I'm sure #10 has a piece broken out of it or is split from what I can feel. I plan on removing the block tomorrow and getting a better look. Did the 50/530 to 70/730 tractors all use the same part numbers?
F-I-T
11-15-2007 16:26:19
 Re: Broken oil filter cast head on 520 in reply to Eldon (WA), 11-14-2007 18:52:37
From a quick check of the parts books, I see the 520 body and head, numbered B 2303 R and B2304 R, is shared with the Model '50' and the late-styled 'B', S/N 201,000 and up. Ought to be quite a few of those around.
Frank
Eldon (WA)
11-15-2007 17:10:48
 Re: Broken oil filter cast head on 520 in reply to F-I-T, 11-15-2007 16:26:19
Yup that's the number. I pulled the block today and took a closer look....the section right next to the boss is broken out, about an oval area 1/2" by 1". It looks like the metal is real thin in that area. It almost looks like it had to be hard water to break it like that. Thanks for the help!
Mike M
11-16-2007 05:52:49
 Re: Broken oil filter cast head on 520 in reply to Eldon (WA), 11-15-2007 17:10:48
More like a hard rubber gasket for the filter cover and too large of wrench.
F-I-T
11-16-2007 08:12:39
 Re: Broken oil filter cast head on 520 in reply to Mike M, 11-16-2007 05:52:49
10-4.
