'48 B Power-Trol cont. - PatB, F-I-T
C DC
11-14-2007 16:14:07
Housing number A3604R and PCV-99680.
F-I-T; I like the idea of getting the right parts together to run either without having to change the set-up. Thanks for the info.
PatB; when I get the right parts, I"ll tweak the screw and see if it works.
Thanks.
F-I-T
11-14-2007 16:46:39
 Re: '48 B Power-Trol cont. - PatB, F-I-T in reply to C DC, 11-14-2007 16:14:07
third party image
Not sure if the selector valve will work with the older A3604R housing. Do the plugs attach via large knurled nuts? The numbered series tractors used newer P-Trol box for which the selector valve was designed. On that box, the A5349R, the plugs are held in using a lever and leaf spring on the right hand side of the box. I am not sure that selector valve will fit to your box using the knurled nuts. I can't say that I have tried it on an older style box, so I can't say for sure, but I'm doubting it at this point. Hopefully someone who has personal experience can direct you on that point.
Here's a photo of the newer styel with the selector valve in place.
Frank
C DC
11-14-2007 17:22:20
 Re: '48 B Power-Trol cont. - PatB, F-I-T in reply to F-I-T, 11-14-2007 16:46:39
third party image
I have the selector. You can also see the linkage right below the battery cable, which does not connect to anything. I understand it is not used with the power-trol?
There are male hydraulic fittings where the knurled caps should be. I don't have any other parts.
wilamayb
11-14-2007 18:58:21
 Re: '48 B Power-Trol cont. - PatB, F-I-T in reply to C DC, 11-14-2007 17:22:20
I've never seen one set up just like yours. You have the normal power-trol fittings to operate a remote cylinder but someone has put Male ISO fittings on the tractor meaning that the implement would have to have female ISO fittings which is backwards from anything we have ever learned.
I cant tell all I need to know from your piture, ( Its a little small) but If your power-trol plugs are held in by a threaded cap the suggested SCV will not work for you. If you have the later style of power-trol that has the couplers held in by pins on the side the suggested valve will work. The very late B tractors use the same couplers a 50,60,70 tractors.
I see your tractor is a round axle which means it should have the threaded style plugs from the factory, but who knows what is there since you had power-lift from the factory and then swapped over to powr-trol.
Mike M
11-14-2007 18:22:27
You had a power lift that was changed over to a power-trol by changing the valve box. Common and easy swap. You need to just pick up a set of the blank plugs like the bottom one in fits picture and insert them and your rockshaft will then work.
