Adjusting oil pressure ?
THE SMOOTHED DE
11-14-2007 11:46:00
Well i spent an hour in the archives and can't find the anwser i want. I want to try bumping up my oil pressure on the 48 b . The adjustment is just above the oil check valve i'm assuming ? There were several conflicting comments on whether to adjust with tractor running or not so i'm not sure about that either . I have learned how to adjust other models just can't find any details about a late b showing adjusting procedure . It's running pressure at below M at fast idle . It's got 10w 30 in it . Past posts suggest maybe straight 30w would increase pressure also ? Filter assm. is not bent in any way so that looks good. Thanks for any help !
Mike M
11-14-2007 12:32:41
 Re: Adjusting oil pressure ? in reply to THE SMOOTHED DEERES, 11-14-2007 11:46:00
Start it up and turn the screw and watch the gauge at the same time and see where your at. I once had one that went low after a rebuild and when I went to crank up the pressure I barely turned the screw and it shot way up and I think the screw may of been bottomed ? I pulled the whole adjustment assy. off and it had a bad spring in it. So I guess make sure you have plenty of springy travel when you adjust it by going past and then backing it off. I set them to run around H at fast idle and then they go down to about M at low idle.
THE SMOOTHED DEERES
11-14-2007 16:54:33
 Re: Adjusting oil pressure ? in reply to Mike M, 11-14-2007 12:32:41
Thks mike , Have u guys seen any snowflakes up there yet ? Madriver ski resort is patiently waiting down here .
Mike M
11-14-2007 18:25:42
 Re: Adjusting oil pressure ? in reply to THE SMOOTHED DEERES, 11-14-2007 16:54:33
One day a week or so ago ? you could see just a little bit of a flake ? but not really ? I guess up by the lake they had enough to measure.
