430W wheel shimmy
Neal3715
11-14-2007 06:09:54
I have a 430 W that has front wheel shimmy in high gear on the road.It does this on pavement but not on granite, and is worse going downhill than up. Every bushing in the steering has been replaced, all tie rod ends are tight and there is virtually no play in the steering. The pins from the arm on the vertical shaft that ride in the worm have also been replaced. The steering worm has not been replaced, it has a fair amount of wear but can be adjusted so there is virtually no play in the steering wheel. The shimmy does not transfer all the way back to the steering wheel which makes me think the problem is somewhere from the steering gear forward. Any help or ideas would be appreciated.
TIM IN NC
11-15-2007 13:24:31
 Re: 430W wheel shimmy in reply to Neal3715, 11-14-2007 06:09:54
Did you tighten the nut at the bottom of the steering shaft? I had one that had backed off a fair amount resulting in a fair amount of shimmy.
buickanddeere
11-14-2007 15:47:17
That includes the top and bottom bushings in the vertical shaft below the steering gears? I found my 435 has less wobble when the front wheel weights were removed. Next to try is the 5:00-15 tires instead of the 6:00-16's. Dropping the air pressure so the tires squatted a little helped too.
Mike M
11-14-2007 06:38:25
I didn't see mention of setting the toe in ?
Neal3715
11-14-2007 07:17:34
 Re: 430W wheel shimmy in reply to Mike M, 11-14-2007 06:38:25
The toe in is set at 1/4". I have had it set between 1/4"out and 3/4" in with no change in condition. The more air pressure in the tires the worse the condition gets also
Mike M
11-14-2007 10:21:36
 Re: 430W wheel shimmy in reply to Neal3715, 11-14-2007 07:17:34
If everything is tight then it is a mystery ? Don't have a bad rim or wheel bearings do you ? Or maybe a bad tire ? I have some tires on my 50 that don't run true and have a dip in the side wall,but it doesn't go fast enough to bother it.
donwisc
11-14-2007 06:24:52
Went thru exactly what you are on a 40 standard. I finally got it out to a acceptable level by playing with the air pressures on the front tires. I had the pressure up to 50 lbs and it reduced the shimmy dramatically. I know this did not fix it and I only treated the symptoms but the higher pressure allowed less contact with the road consequently the road had less affect on the tires.
One other thing comes to mind is that I had the largest tires specified for the 40 and maybe that had more affect on a worn system.
Good luck Don
