A wide front end.
Lyle Pfeifer
01-29-2000 19:14:01
Any one know which years will work with a 47? Someone once told me that even later model wide fronts will work on it. Mine is a styled single tire front end. Also, anybody know why the gear shifter shifts between gears fine on the same series but when you shift between different sets, it will just sit there and not move until you engage the cluth and pull move the shifter around through the gears. I beilieve 246 are on same shaft and 135 and R are on the other. Something loose or has time taken its toll. Thanks for your help, Lyle Pfeifer.
