7020 Fuel Problem
df
11-13-2007 17:17:04
I have a 1972 7020 w/ the 404 eng. When you first crank it up in thte morning it will start and then cut off. I takes several and I mean seveal turns for it to restart. It kind sounds like the elec. solenoid is shutting off. Any Ideas.
msb
11-13-2007 18:13:39
 Re: 7020 Fuel Problem in reply to df, 11-13-2007 17:17:04
Could be the lift pump check valve is kaput. Try pumping the primer lever before trying to start the engine. That will tell you if that is the likely cause.
