Finding some parts for a B
patsdeere
11-13-2007 16:01:39
Anybody know a good place to find them reasonably priced? Deere wants $49 for them and I just won't pay that. If you have one for sale please let me know. It is the end that connects to the govener arm to the carb (D2887R).
Also, my clutch handle seems to bounce from side to side too much. Is there a sleeve or something that is worn out on it? Or is it just wear that I have to live with or fix some other way?
Thanks.
johns48jdb
11-13-2007 19:53:08
 Re: Finding some parts for a B in reply to patsdeere, 11-13-2007 16:01:39
try marlyn smith at 712-489-2570. nice guy to deal with.
Christopher S.
11-13-2007 18:12:32
As far as the slop in the clutch handle, any good machine shop can machine it for you and add a bushing. An insert is also made that helps to take up some of the slop. In a pinch we have made a thin one bushing out of copper that works reasonably well.
B_Bob
11-13-2007 20:30:11
 Re: Finding some parts for a B in reply to Christopher S., 11-13-2007 18:12:32
I've got a '40 and '50 B, both with the same clutch lever slop side to side. You can get the bushing from JD (and probably other sources) but my problem is removing the pivot pin.....they are both stuck/rusted in really bad and I don't want to take a chance on breaking off the ear on the reduction gear cover trying to remove the pin. It ain't pretty but they still function.
Patsdeere
11-13-2007 21:19:00
 Re: Finding some parts for a B in reply to B_Bob, 11-13-2007 20:30:11
I know what you mean. I heated mine till it was smoking hot, cooled it and tried it about 4 more times. I put some of that stuff PB Blaster on it and just let it set. After I put the back end on I realized that the handle got stuck below the arms on the hydraulic unit. I had the choice to either take the back off again (which I refused to do) or take the pin out. I decided to give it another wack and used a rubber mallet and wooped on it. It gave without much trouble. I about jumped through the roof with joy.
Do you know what the bushing part number is? I don't see one in my parts book.
B_Bob
11-14-2007 04:30:57
 Re: Finding some parts for a B in reply to Patsdeere, 11-13-2007 21:19:00
B177R is the bushing number I found. $6.99 is the listed price.
