'48 B Power Lift
C DC
11-13-2007 08:05:32
Refer to the "48 JD B Owners Manual, I think it"s page 41. In the top picture you can see the lever under the seat area and a link that connects to another lever on the right side of the assembly.
Trouble is, my tractor has the lever under the seat and the linkage, but the assembly looks like the one in the bottom picture. There is nothing for the link to connect too. So, with the p.t.o. and the clutch engaged, when I move the large handle on the left (raise or lower) the shaft does not rotate. What am I missing here?
wilamayb
11-13-2007 21:04:20
 Re: '48 B Power Lift in reply to C DC, 11-13-2007 08:05:32
If you have a lever travelling under the seat then you once had power-lift. If you now have a lever to be used by your left or right hand you most likley have powr-trol. The difference is that power lift is rockshaft only. Powr-trol also has the ability to operate a remote cylinder by putting in the correct plugs. Why dont you shoot us a picture of exactly what you have so that we can go on a little farther with helping you out.
johns48jdb
11-13-2007 19:57:33
how much do you know about the tractor. the reason i ask is it sounds like you have the wrong plugs in the power trol. sounds like the plugs that are in it now are for a remote cylinder and you need to pull those out and put s set in the makes the rocker shafts work. it can't do both. if you just got the tractor then you wouldn't know which plugs are in it. if you have a cylinder hook it up and see if it works. that would tell you right quick which plugs you have. somebody else may be able to tell you the difference between them by looking.
P Browning
11-13-2007 14:24:08
Your Powr-Trol unit may be set up for remote cylinder operation. And if this is the case, the rock shaft won't operate. Find the metering screw; remove cap nut and loosen jam nut. If the screw is turn all the way in, your unit is set up for remote cylinder operation, and in order for the rock shaft to operate, you will need to back the metering screw out some. I am not experienced here, so I say do not back it out too far (say a turn or two at most) before checking operation -- back it out only far enough to make it work. Let me know how things work out, and if I need to dig some -- I can do that too. (PatB)
THE SMOOTHED DEERES
11-13-2007 10:25:44
Cdc sounds like u might need to find a local Deere expert around where u live to help you with your tractor . In person advice is much easier and alot more precise ...
C DC
11-13-2007 12:39:58
 Re: '48 B Power Lift in reply to THE SMOOTHED DEERES, 11-13-2007 10:25:44
I disagree. I don"t have clue who in my vicinity would be a Deere expert, or how to find them.
That is the beauty of the internet and a forum like this. There are many "experts" that read this board everyday.
I think anyone who saw my earlier post, and has a 48 B manual and is familiar with a B, would understand what I was asking.
If my question was not clear, well, that is the challenge of the internet. :>) I apologize.
