Engine Heater - John Deere B
Tim Shanks
11-13-2007 07:31:45
third party image
I"m trying something new this year. I found a way to connect a 6.5ft snow blade to the back of the B and able to lift it. I don"t need to turn it. Anyhow, I was wondering if anyone has an idea for an engine heater to help make the tractor start easier in the winter. Please drop me a line or reply to this post. Thanks
Images:
Link
http://www.shanksonline.com/jdb/JD2.jpg
Mike M
11-14-2007 10:31:25
 Re: Engine Heater - John Deere B in reply to Tim Shanks, 11-13-2007 07:31:45
Your going to be able to clear alot of road fast with that high reverse gear. You may want to flip your tires around the other direction for better traction too.
Bob
11-13-2007 20:30:47
Go to an auto parts or truck parts store that is a dealer for Phillips Temro, and order a block heater with the appropriate pipe threads to replace the cylinder head drain plug.
Mother DEERE has the heaters as well, but Temro will be WAY less $$$.
Mike M
11-13-2007 08:15:43
I think massey ferguson sells one that is 3/4" pipe thread and will screw right in the drain plug hole.
Make sure the engine is in good shape and tune and these 2 cyl. really like to start good in the cold. Thinner engine oil will help them crank better.
old
11-13-2007 07:45:54
Theres a number of ways to do that. They make coolant heaters that go in the lower hose of the radiator if theres room for it. Or if you water pump has a pipe plug that you can take out you can plumb in a heater that one end goes to the water pump and the other end hooks into the block drain. Or you can also get a magnet type heater and put it on the under side of the engine to keep the oil warm but there not as good as the coolant heaters are
