2020 injection pump drive shaft snapped in half!
George in Georg
11-13-2007 06:51:29
Recently rebuilt the fuel injection pump, a Roosa-Master, by carefully following the instructions in the JD/Stanadyne book. All seemed to be well.
Finally had a chance to install the pump back onto the tractor yesterday and again, all went well. Turned the tractor over expecting to get a few coughs before it cranked up, but instead heard a mild metallic "pop" and noticed the pump had rotated about 1/2" from the timing mark I made on the housing. The engine kept turning freely, but nothing from the fuel lines.
Removed the pump and was surprised to see the back half of the shaft still in the pump, the font half still connected to the engine.
I haven't had time to disassemble the pump (again).
Two questions:
1) What could have caused the pump to bind enough to break the shaft?
2) Where to get a new shaft, preferrably without spending an arm and leg?
jdemaris
11-13-2007 10:44:24
 Re: 2020 injection pump drive shaft snapped in half! in reply to George in Georgia, 11-13-2007 06:51:29
US Diesel in Fort Worth Texas is a dealer and will ship. 800-328-0037. They sell OEM Stanadyne and aftermarket and sell to anyone.
Keep in mind, an OEM shaft new from Stanadyne will be over $100 and it probably won't fix anything. It is put in the DB and JDB pumps to act like a fuse and protect the rest of the engine from damage if the pump turns too hard.
With Stanadyne/Roosamaster pumps - Deere always used shear-bolts or shear-shafts.
In regard to small particles of debris, fingerprints, etc. causing the problem - I don't believe it and I've fixed hundreds of pumps over the years. Some done in a very clean environment and some out in field with nothing but a bucket of gasoline and a few rags. I've never had one sieze without finding a clear reason for it. Usually mechanical interference of some sort when it siezes turning slow. When turning fast, it can be bad lube, water in fuel, a lot of dirt, etc.
When you put your pump back together - did you test it first before mounting it? You can make it pump high-pressure fuel just by turning the pump by hand with a large screwdriver and squirting fuel into the inlet with an oil-can. When it picks up prime you feel it turn hard - but not hard enough to break anything. Sometimes something as simple as misfitted or aligned fuel-transfer pump blade, liner and/or back cover can make the pump turn too hard and break the shaft.
Did you try your's first - and if so - did it turn with normal resistance before mounting?
George in Georgia
11-14-2007 12:47:39
 Re: 2020 injection pump drive shaft snapped in half! in reply to jdemaris, 11-13-2007 10:44:24
Disassembled the pump last night, and turns out it was one of the flyweights that got cocked slightly and jammed into the inside of the pump. This was using one of the new/improved governor housings that is all-in-one and eliminates that troublesome gasket. The inside of the pump was scored a bit with a gouge, but it was localized to the front and the rest of the pump was spared. The pump section itself is still in perfect condition.
The only thing(s) I need to replace now are the broken driveshaft, that replacement governor cradle assembly/housing and one of the counterweights that got chippped.
I am lucky, but wonder still wonder how this could have happened.
The local John Deere dealer says the shafts are no longer available from John Deere and his computer shows no one in the country has them. So, I'm hoping one is available from Stanadyne.
Thanks!
jdemaris
11-14-2007 13:15:07
 Re: 2020 injection pump drive shaft snapped in half! in reply to George in Georgia, 11-14-2007 12:47:39
You are supposed to tie back the throttle in "full fuel" postion before mounting the pump. That keeps pressure against the governor weights and keeps them in until the pump is slid over the driveshaft. That goes for all pumps regardless if you've updated the governor cage to the EID or not. Whenever installing a pump - you always look down drive-end hole first, and make sure all is intact and the governor arm tangs are in place. Sometimes with the throttle tied back, you have to stick a large screwdriver into the pump and rotate a bit to make it all lock into place.
Are you sure Deere can't get the shaft? I know you can't with the C model pump, but he DB and JDB pump is used in lots of later equipment.
Maybe it's just a case that Deere no longer sells any injection related parts. I know the shaft is available from Stanadyne, I know somebody that just bought one - but it was over $100. Call US Diesel at: 800-328-0037 They sell to anyone and ship fast.
If you really get stuck, I've got several spare shafts here. Most are from Case 188D and 207D engines, but I think the shafts are the same as used in your Deere.
msb
11-13-2007 07:55:03
Can't remember if the shaft tang is offset or not. Could you have installed the pump 1/2 turn off? Remove the broken part and see if you can turn the pump head with a large screwdriver.If not then I agree with bob. A mighty expensive lesson if the pump head and rotor seized. I ALWAYS blow the pump outlet holes out before installing the banjo fittings.Also wash and dry all parts in JD paint thinner to remove any traces of fuel that attract dust and dirt.Blow them dry too.
Bob
11-13-2007 06:59:27
The "head and rotor" seized, and are "toast".
Might have been a little dirt or moisture in there, or lack of lube (diesel fuel).
George in Georgia
11-13-2007 07:40:37
 Re: 2020 injection pump drive shaft snapped in half! in reply to Bob, 11-13-2007 06:59:27
That would be weird since I saturated everything in Mobil 1 0-30 before, during and after assembly. My workbench looked like a surgical suite. The whole thing is very disheartening especially after the amount of time and effort so far.
Anyways, where's the best place to get a replacement shaft???
Thanks!
jjas
11-13-2007 09:35:09
 Re: 2020 injection pump drive shaft snapped in half! in reply to George in Georgia, 11-13-2007 07:40:37
Did you touch the rotor where it runs inside the head with your bare hands? Just enough of a finger print could have caused enough of a clearance problem. I think the boys are telling you correct, shaft and head have siezed and now it's all toast.
