4020 Draft control
Kemper
11-12-2007 15:46:41
I have a service manual on the way for my 4020,but i need some advice on my draft control,i can only raise the 3 point when the draft control lever is in the bottom slot,if i move it up into the other 2 settings it will not raise at all,is there something i can be checking before my manual gets here? I tried plowing with it today and figured out it wasen't working.Thanks in advance for any help.
mattd
11-12-2007 17:49:50
 Re: 4020 Draft control in reply to Kemper, 11-12-2007 15:46:41
your draft linkage is probably out of adjustment and worn out. when they get out of adjustment they can do some weird things. when you get your manual go through the adjustment procedure and see if that helps
