670 tractor won't crank
gregg ruco
11-11-2007 17:04:53
my deere 670 won't crank. I went through the whole system, but can't detect a problem. According to the operator manual the voltage light and parking light don't light when the key is turned. The oil pressure light does. They should all be lit. I can short out the starter and it will crank. Voltage seems to be proper through the system. Ground is good. Does anyone have an idea?
machinery-man
11-11-2007 17:09:59
 Re: 670 tractor won't crank in reply to gregg ruco, 11-11-2007 17:04:53
I have a 670, have you checked the fuses, also the connections to the solenoid shut off. It has to be an electrical connection. Check the transmission safety switch also.
