'48 B flywheel
C DC
11-11-2007 14:08:43
This seems like a stupid question, but here it goes.
I have the flywheel cover off. While the tractor is running, it looks like the flywheel is out of round, like it"s not balanced. I can"t really tell if it is an optical illusion from dirty vs clean surfaces or not. It looks like it is a cast flywheel. Were these perfectly smooth in rotation? The tractor does have a little vibration, particularly at a high idle. How much shaking or vibration is normal? There or no abnormal noises or clunking.
wilamayb
11-11-2007 16:49:41
 Re: '48 B flywheel in reply to C DC, 11-11-2007 14:08:43
I have a late B. It does not shake at any speed, but it does have a resonance at mid throttle. It does go away at full throttle. I'm with the others in thinking that your clutch driver may not be put on the crankshaft with the correct orientation. Take off your driven and floating discs. I'll be you'll see that the arrows do not line up. If not just pop it off and align the arrows and push it back on.
johns48jdb
11-11-2007 16:34:53
i'd say you've got a bad problem, but can't tell you how to fix it except look at the clutch as others have said. don't know i'd run it a lot until i was satisfied things were ok. got a lot of mud piled up on the back side of the flywheel by chance? lots of luck
chris jackman
11-11-2007 16:32:25
Almost every 2 popper ive owned has shook the tires, I wouldnt worry about it.
Mike M
11-11-2007 16:00:29
they do not run true,but you shouldn't be shaking the tires off the rims either ! Sounds like you and hoss have fylwheel or clutch driver on the wrong splines throwing off the balance. They used to put these 2 cyl's up on pop bottles running at the fairs for demo of how smooth they were.
THE SMOOTHED DEERES
11-11-2007 16:52:37
 Re: '48 B flywheel in reply to Mike M, 11-11-2007 16:00:29
The smooth and balanced running of the motors were one of Deere's biggest sales pitches !
Hoss in Maine
11-11-2007 14:43:06
C DC,I"m sure your flywhel is ok.As for the vibration at a high idle my 47 A will shake the tires nearly off the rims! Later Hoss
C DC
11-11-2007 14:51:35
 Re: '48 B flywheel in reply to Hoss in Maine, 11-11-2007 14:43:06
Thanks Hoss, that makes me feel better. I noticed today that the right tire was doing just that. Looked like it was made of jello! LOL
