4020 rockshaft leak
8850dave
11-11-2007 05:06:38
I have console 4020 that started to leak out back of rockshaft cover spraying oil out the bottom. What is the possible cause, I let the 3 point arms down and the oil stopped apraying out.
rexhellwig
11-11-2007 06:32:01
 Re: 4020 rockshaft leak in reply to 8850dave, 11-11-2007 05:06:38
third party image
If I understand your description right, all you need is a 15/16" socket, remove cover {10}, and replace seals {11 and 12}.
If this isn't where it's leaking, you might need an experienced advisor.
msb
11-11-2007 05:09:45
Neverv saw it happen before, but it sounds like the rockshaft valve housing gasket or o-ring has blown.
msb
11-11-2007 05:09:39
