2010 Diesel Replacement engine?
CPeter
11-10-2007 19:53:24
I was talking to a neighbor today and he has a 1961 2010 Diesel that has a bad head and other problems. He would like to swap in a replacement engine. Will anything else fit? This is a working machine, not a show tractor and he cares nothing about keeping it original. His comment to me was about using a Perkins Diesel and wondered if it has a SEA bolt pattern on the bell housing?
CPeter
4020LP
11-11-2007 09:11:48
 Re: 2010 Diesel Replacement engine? in reply to CPeter, 11-10-2007 19:53:24
What jdemaris said is absolutely right. There's no Perkins or any other brand of engine that will fit without a LOT of adapting---probably far more than the tractor is worth. I'm a JD guy to the end, but very likely the best thing for your neighbor to do is find a different tractor, say a JD 2020 or JD400.
jdemaris
11-11-2007 06:41:01
As far as I recall - the 2010 engine does not use a standard SAE pattern - it uses the older Deere gas-engine two-cylinder pattern from the 420-430 series. In regard to bolt-in swaps, any 1010 or 2010 gas or diesel - will fit along with the power-unit versions used in combines. Seems the easiest and cheapest swap would be to put in a gas engine from a 2010 or combine. That would give you the same power and there is better parts availability for the gas engines - as compared to the diesels.
BLinWMi
11-11-2007 15:40:24
 Re: 2010 Diesel Replacement engine? in reply to jdemaris, 11-11-2007 06:41:01
Got to thinking from your response, Could a guy take a junk 2010 engine out and put in a 2 cyl from a 420/430? I know the 145/165 combine engine are far more available but everyonce in awhile I see the 420 engines for sale.
NTW ROSEBUD
11-11-2007 06:32:29
A 2010 JD IS NOT WORTHY OF ANYTHING AS GOOD AS A PERKINS ENGINE. BEST TO SEND IT TO SCRAP YARD.
