1951 John Deere G Power-Trol
George Jones
11-10-2007 17:55:42
I have replaced the hydraulic piston seal three times, the cylinder has also been replaced. Each time the system works for a flew hours and then the lift drops unless I keep the control lever in the up position. I replaced the inter and outer check valves with new ones. No change the lift does fine in lifting but will not stay up.
"Help" Do I just fine another control valve?
buck eye al
11-13-2007 15:06:03
 Re: 1951 John Deere G Power-Trol in reply to George Jones, 11-10-2007 17:55:42
Are you talking about the rockshaft or a remote operating via hoses plugged into the side of the powertrol valve body? Not sure what you have or are working with. Need a bit more info.
George Jones
11-14-2007 20:57:52
 Re: 1951 John Deere G Power-Trol in reply to buck eye al, 11-13-2007 15:06:03
No, I am talking about the tractor equipment, examble my scrape blade. Tractor will lift the scrape blade fine but when the operating valve reaches the upper limit and trips back to neutral the scrape blade just creeps down within a minute or so.
I have replaced hyd piston seal,the hyd cylinder and both inter and outer check valves. I have not used the remote part of the control valve.
