B PTO oil
matthew h
11-10-2007 17:51:29
Got to spend some quality time with the new "B" today. Could not wait to change the fluids. Motor and breather - no surprises. Tranny/Rear was water with a little oil floating on top. Flushed and refilled with 85W90. Concern - there were two plugs under the tranny. I pulled both. One was dry - what is it? Problem. I pulled the plug under the pto thinking it my share fluid with rear. Apparently it does not. I cannot see where it fills. Help appreciated. Also, there is a petcock on the side of the powertrol. Is this the fill level for powertrol?
thanks. ps ordering that manual now.
matthew h
11-11-2007 06:21:59
 Re: B PTO oil in reply to matthew h, 11-10-2007 17:51:29
thanks much
Mike M
11-11-2007 05:03:07
One of those 2 plugs close to each other under the tranny was just to plug the hole drilled in the case for the pto shifter rod. I hope you also found the large plug above the drawbar under the rear axle housing it takes a 3/4" drive breaker bar to remove. If not you didn't get all the old oil out of the tranny and rear end. The plug you found clear to the back by the pto but off to one side is to drain the hyd. oil.
matthew h
11-11-2007 06:17:11
 Re: B PTO oil in reply to Mike M, 11-11-2007 05:03:07
Thanks, found it and drained it as well. Took most of a 5 gal pail to refill
RobMD
11-10-2007 18:04:29
what year B do you have? early ones had 140 weight oil in the tranny.
The pto gets the power-trol oil. I just put 10w30 motor oil in it. The petcock you see is the fill level for the power trol. The Pto is the pump for the hydraulics.
matthew h
11-10-2007 18:59:00
 Re: B PTO oil in reply to RobMD, 11-10-2007 18:04:29
It is a 1950.
Thanks for the info. There is also a plug on the bottom of the powertrol body (above the pto). Dark caught me before I got it out. Is there any need to worry about pulling this plug if all the oil drained out below the pto? Lastly, I assume that the oil level is with the lift rock shaft in the down position. Is this correct?
thanks again.
RobMD
11-10-2007 19:50:35
 Re: B PTO oil in reply to matthew h, 11-10-2007 18:59:00
You will want to pop that plug as well to see if there is any residual oil left in the system. Perhaps rinse out with kerosene.
Yes, the rockshaft should be 'down'. You can tell this by taking a look at the end of the rockshaft itself; there is an arrow which should be pointing sort of downwards to the drawbar.
Again, im not sure on the tranny oil. Your book will tell you if its 90 or 140 weight.
