Hood and belt brake on B
wayneh
11-10-2007 08:47:57
I've had a 48 B for a few years now, and since it's cold and rainy here now I am taking it apart to clean it up and paint it this winter. I've worked on a lot of cars, trucks and tractors but this is the first real work I am doing on the B. I have the IT shop manual but the one I have does not answer my questions.
I took the hood off. That was a lot of pain! Can I assume that the gas tank stays attached to the hood when you remove it? Who thought that up...
I need to install a new pulley brake pad, and to get the rivits in the actual brake needs to come off so I can press the rivets in. If I take the bolts out of the assembly that holds the clutch fork will they just slide out and slide back in, or do I have to remove the discs etc? I'd rather not mess with that since the clutch works well and pops nicely already.
Thanks for the help!
Wayne
www.flymha.com
CLW
11-10-2007 20:23:37
 Re: Hood and belt brake on B in reply to THE SMOOTHED DEERES, 11-10-2007 08:47:57
Wayne, the guy that came up with the tank/hood idea is the same one that came up with the great muffler replacement design on the A, B and H.
wayneh
11-10-2007 10:39:59
 Re: Hood and belt brake on B in reply to P Browning, 11-10-2007 09:52:14
Pat/Kurt: Thanks so much for the help. Pat, that info was perfect. Since it appears to not be too much drama to pull the fork out I'll do that, especially since I have a new rivet brake pad ready do go on in my hands. I'm not going too crazy on this, but I might as well keep it like it was as much as I can.
thanks again,
Wayne
Kurt_JDB
11-10-2007 09:40:53
 Re: Hood and belt brake on B in reply to wayneh, 11-10-2007 08:47:57
Wayne,
Yes, the hood and tank come off together.
You can also remove the clutch/fork/brake assembly without taking apart the various disks.
Just for your Info, adjusting the clutch is very easy to do, and I wouldn"t worry too much about it, if you find a reason why you might want to take it apart.
Kurt
wayneh
11-10-2007 09:50:01
 Re: Hood and belt brake on B in reply to Kurt_JDB, 11-10-2007 09:40:53
Kurt: Thanks for the fast reply! OK on the clutch. I have adjusted that and it was easy, I guess I was nervous about messing up something that works perfectly well now. (like I've never done that before...) But, I'll take that off and be done with it, and then I can rivet on the new pad.
regards
Wayne
