630 ignition/light switch
deereford
11-09-2007 17:36:36
Where can I purchase a reliable ignition/light switch. The last one from John Deere lasted only a few months. I have also had reliability issues with a temperature gauge from JD> Thank you in advance for your assistance. deereford
Mike M
11-10-2007 06:16:04
 Re: 630 ignition/light switch in reply to deereford, 11-09-2007 17:36:36
If you still have your original switch take it apart and clean it and it will likely outlast the new ones. I have even repaired loose terminals by restaking the rivets or if you need a new rivet the copper split ones for dog tags work.
wilamayb
11-09-2007 21:05:46
Generally speaking ignition switches dont fail. What problem are you seeing with your switch?
Guages are a different deal. Guages have been farmed out to whoever is cheapest at the time. The price sometimes sacrifices functionality and reliablity.
deereford
11-12-2007 18:01:57
 Re: 630 ignition/light switch in reply to wilamayb, 11-09-2007 21:05:46
Thanks for your response. My replacement switch allows, at times, the tractor to run only on the starter bypass circuit and other times to stop when lights are turned on. This is unpredictable but usually more common on cold start up. deereford.
