1952 JD A powrtrol
Larry Allen
11-09-2007 05:22:32
Need some help when you lift rear bar the lever does not return to neutral quickly. Then the bar will lower down by itself we have the ball powrtrol.any help would be appreciated
55 50
11-09-2007 07:42:35
 Re: 1952 JD A powrtrol in reply to Larry Allen, 11-09-2007 05:22:32
What do you mean by the "rear bar" and what do you mean by the "ball powrtrol"? Explain things a bit more and maybe someone can then provide some help.
lallen
11-10-2007 16:06:06
 Re: 1952 JD A powrtrol in reply to 55 50, 11-09-2007 07:42:35
three point hitch is the bar-- releases after the lever pops back to neutral--the height of the bar should remain the same until lowered--the powrtrol is the newer type with roller ball bearings that shut and open the hydraulics valves.but what happens now is lift up three point hitch lever pops back to neutral when relief valve kicks in. once that happens the tree point hitch and bar lower slowly by its self
