49 B piston rod question
Randy G.
11-08-2007 20:29:21
After removing the pistons I noticed no bearings between the rods and crank. Shouldn"t there be some? The service manual shows none too! The play between the crank and rods is very sloppy. There was a shim between the rod and rod caps though. Is there supposed to be rod bearings or is all adjusting done with the rod shims? Thanks for your help. Randy G
Green Relics
11-09-2007 10:47:41
 Re: 49 B piston rod question in reply to Randy G., 11-08-2007 20:29:21
Randy, If it's really sloppy as you say you best mic the crank for size. You may need more than rebabbited rods if it's been rapping. John
johndeereman
11-09-2007 05:16:41
its the same price for remanned rods and you dont have to wait i prefer babbit rods the take more abuse and you can adjust with shims as they wear instead of replacing bearings
ET
11-09-2007 04:41:26
If it comes down to rebabiting the rods you might look for a set of 50 rods. They have an modern insert and fit right in.
Randy G.
11-08-2007 21:38:02
Yes Bob but I've never delt with them. Looks like I'm about to. Who does a good job of re-babbiting?
Anything I should know about the installation of the re-babitted rods? Any help would help. Thanks
Bob
11-08-2007 20:32:41
Are you familiar with the term "babitted rods"?
