3020 grinds going into reverse
pitchfork
11-08-2007 19:03:57
What would cause a 3020 to grind while going into reverse? It's like the gear needs just a little shove to mesh correctly.
MSM
11-08-2007 22:15:52
 Re: 3020 grinds going into reverse in reply to pitchfork, 11-08-2007 19:03:57
Synchronizer is worn out, next symptom will be jumping out of reverse,and if you continue to run it won't go into reverse at all.
Gerald J.
11-08-2007 19:57:50
Clutch not releasing all the way, too much pedal free play?
Could be the synchronizers, on the clutch, since its not sliding gears in the right side of the shifter.
Gerald J.
pitchfork
11-09-2007 18:42:43
 Re: 3020 grinds going into reverse in reply to Gerald J., 11-08-2007 19:57:50
It will inch back bit by bit if I don't let the clutch out all the way.However it just grinds like the gears are barely touching. The other gears are fine.Is there a top trans cover that I can remove for a better look?
Gerald J.
11-09-2007 20:06:21
 Re: 3020 grinds going into reverse in reply to pitchfork, 11-09-2007 18:42:43
Its not gears its a toothed clutch with synchronizers. The clutch teeth are probably ground off or the linkage isn't shifting all the way in gear.
There is a top to the transmision under the floor deck. I don't know what you can see or get to with that cover removed. Much transmission work seems to require splitting the tractor.
Check the shifting mechanism up in the dash and the links down to the transmission for wear and slop. That could be contributing to the problem.
Gerald J.
pitchfork
11-10-2007 17:11:45
 Re: 3020 grinds going into reverse in reply to Gerald J., 11-09-2007 20:06:21
Thanks for all the info! This is my first JD ( usually have Massey Ferguson). The person I got it from was selling it for a friend but said the owner split the tractor and replaced some parts. It was ok for a while but started acting up again. Why do you think only reverse? I haven't had a chance to check out the linkage- bad weather.
