1010 special
Roy in georgia
11-08-2007 16:10:10
my 65 1010 gas backfires when I start it,continues popping for a bit,then when it is good and warm it runs fine.I have completely tuned it up and rebuilt the carb. I have come to the conclusion I need a distributor. If anyone has suggestions on some adjustments to make feel free I am not familiar with the points but have delt with them from time to time with no problem. I plan on rebuilding this engine later but for now I just want to keep my driveway smooth and small field cut.this thing is starting to cause me to wish I left it at my father-in-laws.
thanks,Roy
fordson64t
11-08-2007 17:24:29
 Re: 1010 special in reply to Roy in georgia, 11-08-2007 16:10:10
Have you tried pulling the choke out a little and see if that will help it until it warms up. This will isolate the carb from ignition. My 2 cylinder always does that when it is cold. Pulling the choke just enough to stop it from backfiring may help you.
Roy in georgia
11-08-2007 19:47:31
 Re: 1010 special in reply to fordson64t, 11-08-2007 17:24:29
yes sir, I did with no effect it started this problem and at that point I tuned it up rebuilt the carb. changed plugs and wires again. Last weekend the points burnt out that is why I think it may be the distributor.Thanks for the friendly reminder on the choke.
Kurt_JDB
11-09-2007 10:48:28
 Re: 1010 special in reply to Roy in georgia, 11-08-2007 19:47:31
Have you tried a new condenser?
Kurt
Roy in georgia
11-09-2007 16:12:02
 Re: 1010 special in reply to Kurt_JDB, 11-09-2007 10:48:28
yes,sir sure did twice
BUTCH GA.
11-08-2007 16:28:46
Roy I can't help you with your problem but I have a 1010 torn down and it's major dollars for parts for them. I'm really considering parting this one out.they are not one of John Deeres greatest inventions.
Bob
11-08-2007 16:40:19
 A BIT EXTREME, don't you think? in reply to BUTCH GA., 11-08-2007 16:28:46
A BIT EXTREME, don't you think, parting out a tractor 'cause it MISFIRES???
BUTCH GA.
11-09-2007 04:22:07
 Re: A BIT EXTREME, don't you think? in reply to Bob, 11-08-2007 16:40:19
I'm not parting mine out because it miss fires. mine has a busted block. when he pulls his down to overhaul it he will find out what i'm talking about.
Roy in georgia
11-08-2007 19:36:37
BOB! I never mentioned parting it out so,with that out of the way I like this tractor and plan on keeping it just getting tired of the little things when it never gave father-in-law any trouble. even with very old ignition parts fired up and ran every time now that I have it it seems to be giving up in many areas. I would like to buy a parts tractor but $ is a problem at this point.I work in construction and with the housing market like it is my finances are not well.
Bob
11-08-2007 20:49:40
 Re: A BIT EXTREME, don't you think? in reply to Roy in georgia, 11-08-2007 19:36:37
Roy,
I realize YOU never mentioned parting it out, but "Butch" did.
I guess it's lucky SOME tractors "give all" so others can be repaired with their parts, but I never had the stomach for "butchering". In fact, I've $aved MANY that probably $HOULD have been parted out.
I'm up on the northern plains, where a 1010 or a 2010 is a rarity, and I have a special liking for them.
Perhaps you saw the photos of a 2010 still working up here, which I posted a few weeks ago?
Third Party Image
Ron Pruitt
12-06-2007 19:39:00
 Re: A BIT EXTREME, don't you think? in reply to Bob, 11-08-2007 20:49:40
Bob,
I have an early model 1010 diesel utility I want to get rid of if you want it. It is a true 1010 Utility. Not a row crop utility. Im told these are very rare. I can send photos if you want to see it. It needs some work but for the most part it is all there.
Ron Pruitt
Roy in georgia
11-09-2007 16:26:54
I still use mine from time to time mostly to scrape my driveway for the wife's mustang to ride on a smooth dirt driveway that is over 1000 feet long and up a hill so when it is time to smooth it out I hate the time it takes to get it going.Is this the only photo you posted or should I look for more.
BUTCH GA.
11-09-2007 05:26:36
Bob
Before you go rakeing me over the coles make sure you know all the story. I been working on this 1010 for a older friend that had a stroke and very limited funds. the block is busted and not repairable. Have not been able to find a running engine. so thats the part you didn't know. he may never be able to use it again and needs what ever money he can get from it, if he decides to part it out. so if your so fond of these tractors come on down to south Ga, and buy this one and you can give it new life.
Butch
Bob
11-09-2007 07:43:07
 Re: A BIT EXTREME, don't you think? in reply to BUTCH GA., 11-09-2007 05:26:36
Butch,
I WAS NOT "raking you over the coals".
It's YOUR tractor, and you have my permission to WHATEVER the heck you want with it!
However, Roy and I are going to keep our old iron RUNNING!
Bob
11-08-2007 16:25:40
Have you checked for excessive play in the distubutor shaft bushings, and that the centrifugal advance mechanism is intact, loose, and free of excessive wear?
Roy in georgia
11-08-2007 19:49:51
 Re: 1010 special in reply to Bob, 11-08-2007 16:25:40
that is what I was thinking do you know of a rebuild kit or someone to rebuild it. it is not the Delco
Bob
11-08-2007 20:40:20
 Re: 1010 special in reply to Roy in georgia, 11-08-2007 19:49:51
Distributor parts are now very hard to find. I should check on JDPARTS to see what is still available for the Prestolite distributor from Deere.
I have often made a custom bushing on the lathe when one is not readily available, and, of course, there could be problems with the springs and mechanism in the advance.
As far as burning points, some of these tractors had the ballast resistor as part of the ignition switch, and some had a separate porcelain ballast resistor. If your's has a coil that requires an external ballast resistor, and there's none in the circuit, that could be hastening the demise of the points.
If you are set up to accurately measure the primary current (engine "off", key "on", points closed), a good "rule of thumb" is to look for from 3 to NOT over 4 Amps of current. MORE will "kill" the points, and make the coil run HOT.
