Hey Pat Browing and others
Mike M
11-08-2007 06:40:57
Pat; I just got to thinking ( I know very dangerous )about these JD H tractors. From up north here in Ohio I have seen MANY with cracked cyl. heads,blocks and even the transmission case bottoms from water getting in and freezing. I was just wondering if you have seen/heard of this in other parts of the country and if in the book have any cautions for new buyers to examine these areas ? I often even forget to check the tranny bottom.
buickanddeere
11-09-2007 03:24:00
 Re: Hey Pat Browing and others in reply to Mike M, 11-08-2007 06:40:57
Fewer cracked engines up here. Seldom do operators take the chance of being lucky enough to get away with just water as coolant. It always too cold for too long to ever dream of trying to cheapo your way without using antifreeze. Or at least substituting oil for coolant in the winter.
P Browning
11-09-2007 07:36:31
 Re: Hey Pat Browning and others in reply to buickanddeere, 11-09-2007 03:24:00
Many of the freeze problems are rooted in the past when farmers did not have confidence in Prestone & alcohol just wouldn't stay in a John Deere because of its operating temperature and no pressurization. Some bad-news stories circulated concerning Prestone, and folks I knew weren't willing to take a chance with it. I don't even recall the reason or what ill effect it was supposed to have! Ergo the reliance on water and remembering to drain. Then there are those who just fail to get around to taking care of business and get caught with water in the tractor and plunging temps! (PatB)
JMS/.MN
11-08-2007 10:01:00
Bought an R with the same problem- broken block. Welder told me he saw a lot of them when farmers used plain water all summer, drained them in the fall, and they cracked over winter since not all the water drained out. Wrapping a pipe with screen would keep the mice out and still let it drain.
WTW
11-08-2007 09:45:11
Mike , Here in Iowa we call that "Hard Water" damage. A few years ago I went tractor pulling in the early winter and when I got to Indiana they had a real bad cold snap and one of my two tractors would not move off the truck due to "Hard Water" about 3/4" deep at the bull gears. Luckily it was shallow and a tug from another got it loose. We also ended up pulling on frozen ground inside the fair building. That was a first and hopefully the last. When I got it home a space heater and some time I got it all drained out. doesn't take much water to do allot of damage luckily I didn't have any. DW
P Browning
11-08-2007 07:36:56
Mike -- Thanks for the heads-up. I am about to go in and make some updates for the JD-H website, and this would make a fine issue to identify in the JD-H Buyer's Guide. And -- to be frank, I rather imagine this should apply to all tractors, and a close inspection should include checking as much as you can of the upper & lower cast iron radiator tanks. I've also found the lower water pipe (cast on some models) to be cracked.
Mike M
11-08-2007 08:05:41
 Re: Hey Pat Browing and others in reply to P Browning, 11-08-2007 07:36:56
With the design of their shifter they seem to have more trouble with water in the tranny than others. Seems like even down south you must get enough cold snaps to bust up stuff too ?
F-I-T
11-08-2007 10:56:42
 Re: Hey Pat Browing and others in reply to Mike M, 11-08-2007 08:05:41
The "H"s sure have a lot water intrusion down here in the south, especially if you let one sit outside even just for an evening, as the rains come quick and furious. It doesn't often get cold enough down here to crack cast iron, but just as I say that, we had a low of 28* this am in Tallahassee, which is pretty cool for mid-November for us.
That "H" design with the leather boot seems to be particulary prone to water going down the quadrant. Once the leather wears and tears a bit, you're left with pretty much a funnel to guide rainwater down the shift lever. I once fitted a Frigidaire washing machine shaft boot to my first "H" back in '68, and that really worked well. The neoprene held up well.
Frank
P Browning
11-08-2007 11:30:38
 Re: Hey Pat Browning and others in reply to F-I-T, 11-08-2007 10:56:42
Frank -- How about a Plumber's Friend? Wouldn't that be a hoot installed on your H tractor? (PatB)
Mike M
11-08-2007 11:05:55
 Re: Hey Pat Browing and others in reply to F-I-T, 11-08-2007 10:56:42
dang !!! it was warmer than that up here in northern Ohio I think the news said low of 29* ,but alot of places were slightly warmer.
F-I-T
11-08-2007 11:53:07
 Re: Hey Pat Browing and others in reply to Mike M, 11-08-2007 11:05:55
I was when my wife reported that temp to me this morning. It's only been a low of 56* or so here in Pasadena.
On the plunger, HA, that would certainly be an "it". There sure have been a few project tractors that I thought could have benefited from a good plunging!
Frank
C DC
11-08-2007 07:00:18
My B, (my first tractor) has the top water manifold welded and a baseball sized patch on the bottom of the engine. In the future, I will look for that sort of thing. With all the reference material I have gotten, the only thing I have read is to "clean up" the welds so they wont be so ugly. The owners manual clearly states to have antifreeze in the tractor and check it. I have also read to drain them if you are not going to use it when it is cold.
Mike M
11-08-2007 07:18:42
 Re: Hey Pat Browing and others in reply to C DC, 11-08-2007 07:00:18
Alot of them were drained and then the plug put back in. Well this still breaks them as more is still in there and collects at the bottom. You need to leave the plug out if drained,but then mice get in. I leave 50/50 antifreeze in mine all the time now.
C DC
11-08-2007 07:55:51
 Re: Hey Pat Browing and others in reply to Mike M, 11-08-2007 07:18:42
That"s the thing to do I would think. Keep the mice out and , hopefully, keep it from rusting also.
P Browning
11-08-2007 08:22:19
 Re: Hey Pat Browing and others in reply to C DC, 11-08-2007 07:55:51
CDC -- I think Mike is trying to tell you to leave the plug OUT -- at least long enough to be so very sure all the water is out. He is saying (I think) that residual water trapped in the bottom of the head casting may be sufficient to result in a cracked casting. (PatB)
36 coupe
11-19-2007 03:27:55
 Re: Hey Pat Browing and others in reply to P Browning, 11-08-2007 08:22:19
I used alcohol in my H for 20 years then switched to permanent.No problems for 40 years.Alcohol used to sell for a buck a gallon in the 50s.Every garage had a 50 gallon drum on hand.Evaporation was a problem but 25 cents would buy a quart anywhere.
