jd-b pistons
jdbman
01-29-2000 09:52:06
can enybody tell me how big of oversized pistons i can put in a 39 b and where i can get them.also can some one tell me where i can get a crank stroked in the northern missouri area and how much stoke can be added to a "b" crank. last but not least i have two b blocks one with large spark plugs (w18) one with smaller is one of these a power block one is out of a 39b and the other is out of an early 40b
Brandon Gantt
01-29-2000 11:08:05
 Re: jd-b pistons in reply to jdbman, 01-29-2000 09:52:06
You can put a 7.5 inch crank in a B which is 2 inches over stock. With the stock block you can't bore it much more than 125 thousands better get somebody else to tell you for sure. Call Kieth Merfeld at 319-582-8710 he can tell you everything you need to know.
