730 starting plate
machinery-man
11-07-2007 03:58:39
My older friend was selling the 730 he restored, had repaired the flywheel and the mounting plate. Rebuilt starter. The buyer started and stopped tractor a few times and the mounting bracket broke again. Anyway does anyone know the company making replacements, preferrable cast steel instead of the cast iron original type. The tractor has excellent compression, we rebuilt transmission, paint. Excellent tractor he needs to replace the plate prior to reselling. Thanks
machinery-man
11-07-2007 09:05:09
 Re: 730 starting plate in reply to machinery-man, 11-07-2007 03:58:39
The starter didn't seemed to contact in teeth as deep as possible, but the bracket may have been slightly misaligned from the welding but in cranking it looked like the bracket flexed. A new ring gear was installed. Engine was overhauled and has excellent compression...we heard JD had problems with the mounting plates. There is no other adjustment, proper gasket was installed. If tractor has low compression, I could see where this also might not be an issue.
buickanddeere
11-08-2007 05:39:53
 Re: 730 starting plate in reply to machinery-man, 11-07-2007 09:05:09
The only way to break the starter mounting plate is abuse. I have one here that some technical genius broke with a crowbar while trying to remove it. He should have removed all the bolts before trying to lift the plate off.
machinery-man
11-07-2007 07:03:56
that"s the right thought, but has new starter ring and rebuilt starter, tractor has excellent compression...we heard that JD made a weak plate, but I found one on ebay is cast steel instead of the cast iron...there is a design weak place in the part...maybe the cast steel will hold the load.
F-I-T
11-07-2007 07:47:11
 Re: 730 starting plate in reply to machinery-man, 11-07-2007 07:03:56
I like the idea of cast steel in that area as well, but like B&D, I am wondering if you have a mis-alignment that might be causing the bind so that when the flywheel ring gear comes around to its high-spot, and they all have a slight high-spot, that maybe that is what is giving the bracket a crowbar-affect lift, and crunching the bracket.
Does it look like it broke from being lifted, or did it break as if the force was lateral? I'd piece the old bracket together just enough to use it as an alignment jig. You might have to shim it front or back or both to lift it into position so that the stater engages fully, but never bottoms out in a tooth depression (node). A dial indicator used to find the high tooth could help, too. That's where I would begin...
Frank
Bob
11-07-2007 08:01:33
 Re: 730 starting plate in reply to F-I-T, 11-07-2007 07:47:11
It could just as well be a "low" area, and the teeth climbed over each other, breaking the mount.
Also could be a timing issue.
F-I-T
11-07-2007 08:35:55
 Re: 730 starting plate in reply to Bob, 11-07-2007 08:01:33
Yes, that is very true.
buickanddeere
11-07-2007 05:57:40
We have to wonder what broke the original starter mount in the 1st place and what re-broke it. Should look for a resolve the cause instead of just repairing the symptoms.
