Smoothed Deeres, Without getting too specific, I'll try to give a brief history as I understand and remember it. Production of the GP began in 1927/28 with the Model C. About 100 were produced. However, Ma Deere was afraid orders for Model C would get confused with Model D so they changed the name to GP Standard since it was designed to be a general purpose tractor. The model C's were reportedly recalled and re-serial numbered as GP's. Apparently several were missed. My guess is there is less than a dozen Model C's known about today. About 24,000 GP standards were produced from 1928 to 1930 with a 5-3/4" cylinder bore (small bore). Due to a lack of power, Deere began altering the engine, among other things, to increase power resulting in several low production hybrids including cross-over GP's and 1930 GP's with a larger 6" cylinder bore engine (big bore). In 1931, Deere switched the GP standard completely to the bigger bore engines and produce roughly 6,800 big bores between 1931 to 1935. Early in production of the GP standard, Deere realized a need to develop a tractor to compete with the Farmall F series, so they adapted a GP with a tricycle front end. The experimental versions are called GP Tricycles and the production version is the GP Wide Tread (GPWT). About 5,000 or so GPWT's were produced between 1929 to 1933. The early models had steering similar to the GP Standard and are called side steers while the later models had steering above the hood (like an JD A) and were called top steers. The GPWT top steer was the base model which led to the development of the Model A in 1934. During production of the GPWT, a special need was presented for working in potato fields resulting in the production of the Model P. I am not sure of the production numbers on the Model P but I would guess not many more than a hundred or so, if that many. Another need arose for tractors working in orchards, so Deere adapted the GP standard to produce the GP Orchard (GPO). Approx. 700 or so GPO's were produced between 1931 and 1935. As I see it, the order of collectability would go something like this: 1) Model C, Model P, GP Tri-cycle or any experimental GP. 2) GPWT top steer or GP Crossover 3) GPWT side steer, GP orchard and rarer of GP standards (1928 with 200 series tag, 1933 GP due to low production, or 1935 GP w/oil bath air cleaner) 4) GP big bores 5) GP small bores There were a lot of design changes throughout production of the GP tractors which make them a very interesting tractor to collect. I have several myself and am always trying to find that illusive Model C or Model P that has been tucked away just waiting for me to discover it. I haven't come across it yet, but I am an optimist.
