G Hydraulic won't pick up load
Ben.So.Tex
11-06-2007 08:57:28
I wanted to use my 49 G to pull a crosscut yesterday and it will not raise the 9ft crosscut, When the wheels hit the ground it can't pickup the weight of the crosscut.
I have never used this G for any cylinder work before. The oil level is good. Do I need to adjust something in the lift to make it pickup. I was only intenting to disk about an acre. (CAN'T AFFORT THE GAS THIS THING BURNS TO DISK MORE.)
Dale West
11-06-2007 16:35:51
 Re: G Hydraulic won't pick up load in reply to Ben.So.Tex, 11-06-2007 08:57:28
Can't remember for sure, and don't have my manual handy, but isn't there a cap over an adjustment needle valve that needs to be changed (in or out) to go from rockshaft operation to remote cylinder operation? I think on the right side (looking at rear of tractor) looks like an extra long hex bolt. Hope this helps you overcome your problem. Dale
MEANJDK
11-06-2007 13:26:06
Mike M, If the gasket behind the powertrol was blown out, would it still hold pressure in the external cylinder? I know that the rock-shaft will not stay up, or lift much if the gasket is bad.
Just something to consider..... ...
Mike M
11-07-2007 06:02:06
 Re: G Hydraulic won't pick up load in reply to MEANJDK, 11-06-2007 13:26:06
That is a possibilty ? I also think it depends on where he has his remotes hooked into. If using the factory tips straight out the back this bypasses the rockshaft. A simple pressure gauge hooked into the remote would tell the answer.
Mike M
11-06-2007 10:29:48
Those old tractors didn't have much pressure 700-800 psi comes to mind ? might be wrong ? so what dia. cyl. do you have ? you might just need a bigger cylinder.
Ben.So.Tex
11-06-2007 11:09:18
 Re: G Hydraulic won't pick up load in reply to Mike M, 11-06-2007 10:29:48
3 Inch. cylinder?
Thank.
Mike M
11-06-2007 12:30:52
 Re: G Hydraulic won't pick up load in reply to Ben.So.Tex, 11-06-2007 11:09:18
Wouldn't hurt to put a gauge in the hyd. outlet and check it. If it is way low it may need the relief shimmed up to boost the pressure. I would think if you had 700-800 psi that 3" cyl should lift a 9 foot disc ?
