Help on wide front end 530
Bob Antes
11-06-2007 08:12:20
Need ideas on how to break loose square tube front end so that I can change width. I have used heat, porta power, rust busters and I still am not totaly sucessfull
ET
11-07-2007 08:12:18
 Re: Help on wide front end 530 in reply to Bob Antes, 11-06-2007 08:12:20
I have one to loosen and have been kicking around the idea of getting the salamander heater set up about a foot away from the casting and let run awhile. Thats a big piece of iron for a torch of any size.
JDZ
11-06-2007 08:52:43
 Re: Help on wide front end 530 in reply to Brianderry, 11-06-2007 08:12:20
I helped my dad do this a few years ago which happened to be on the wide front for his 530, also. I don't know if your axle is still attached to the tractor or not. Ours was not. We set up chains and a winch between two trees to "stretch" it. We used one of those big torches that go on a 20 lb propane cylinder to heat the cast iron. We put a bar through one of the holes on the adjustable axle stub and pounded on that with a sledge hammer. It took a long time and a few choice words to get it to budge, but eventually, it did. Water to keep the stub cool, while heating the cast iron will probably help, because the stub will want to heat up faster than the cast iron.
