John Deere B Carburetor
Andy Motteberg
11-05-2007 20:52:28
Will a DLTX-10 carburetor replace a DLTX-34 carburetor? What is the difference between these two carburetors?
Thanks.
Duane Larson
11-12-2007 14:51:47
 Re: John Deere B Carburetor in reply to Andy Motteberg, 11-05-2007 20:52:28
Andy,
The throttle-end bore (and hence the throttle plate) is larger on the 34 - 1 5/16 on the 10 and 1 3/8 on the 34. The nozzles are also different, along with some internal passage sizes. While most DLTX carbs will bolt-up properly, there are some significant differences in the various models.
CalJim
11-06-2007 20:36:16
According to Robert's Carb Repair you can temporarily substitute a 34 or 67 for a 10 as long as it's just a parade tractor. I installed a 67 on my 36 B while waiting for the correct model 10 to be rebuilt. Ran like a champ, in fact it was hard to tell any difference once I put the 10 on. That being said, I'm not sure how the smaller 10 would work on the newer, larger styled engines. CalJim
Duane Larson
11-06-2007 05:46:30
Andy,
P Browning
11-06-2007 06:37:52
 Re: John Deere B Carburetor in reply to Duane Larson, 11-06-2007 05:46:30
An interesting side note -- Field Service Bulletin 137-S issued 9-15-1942 instructed JD techs to be more diligent when installing carburetor-to-manifold gaskets. It seems that gaskets made for the "H" model with a bore smaller than all the rest were ending up being installed on tractors other than the "H" -- resulting in lack of horsepower. The interesting part -- the "fix" was to discontinue supplying the smaller gasket to dealerships for it turned out, using the larger ID gasket (one-size-fits-all) on "H" tractors worked out just fine. One has to wonder how much head-scratching was done before this problem was discovered! (PatB)
wilamayb
11-06-2007 04:03:35
Andy
I once thought that the 10 was offered with the 149 in engine while the 34 was offered with the 175 in. engine. This is not true. B tractors between SN 60000-96000 had a 175 engine with a 10 carburetor.
All that said the 34 must have been a better performer as it was used on the 96000 and up tractors making about 2 more horsepower than the tractors before 96000. I would almost dare to guess that the bore is larger on the 34 and I would almost guess that it had a different nozzle.
I've serviced a few 34's but never a 10. Too bad you dont have both to put them on the bench and compare. Maybe some of our carburetor experts have had both on the bench at the same time.
Andy Motteberg
11-06-2007 09:38:43
 Re: John Deere B Carburetor in reply to wilamayb, 11-06-2007 04:03:35
I do have two, the 34 has bad threads, but we have a 10 with good threads.
