Does a powerblock have petcocks?
Bob in NC IA
11-05-2007 18:59:05
I thought all old powerblocks had petcocks. Someone told me that since my block had petcocks, it wasn't a powerblock. Is that true? Thanks.
gpuller
11-06-2007 08:29:17
 Re: Does a powerblock have petcocks? in reply to Brianderry, 11-05-2007 18:59:05
Bob in NC IA said: (quoted from post at 21:29:39 11/05/07) How much horsepower should a late "G" have with a powerblock, flathead, big nut G carb, and a gas manifold if it is stock? Thanks.
Isn't exactly "stock" if its got a PB, flat head and gas manifold. LOL
If everything is in good shape, a G with that equipment could be 70+hp.
Bob in NC IA
11-05-2007 20:29:39
 Re: Does a powerblock have petcocks? in reply to Bob in NC IA, 11-05-2007 18:59:05
Thanks for all of the replys. The previous owner told me the late model "G" had a powerblock. I took his word. Tomorrow I'll have to check the block as has been suggested. How much horsepower should a late "G" have with a powerblock, flathead, big nut G carb, and a gas manifold if it is stock? Thanks.
Duane Larson
11-05-2007 20:07:04
As you have learned, they don't have petcocks - that is one reason they weren't available for the unstyled series of tractors - too much compression to turn over by hand, according to an engineer I spoke with who worked on the PBs. Being a sleeved block also meant drilling thru both sleeve and block, which they apparently didn't want to do.
Mike n Mo
11-05-2007 19:08:24
To the best of my knowledge, none of the TSC powerblocks had petcocks or provisions for them from the factory. I have put them on several, but you have to drill and tap the block to install them. A TSC powerblock will have raised letters on the top behind the upper water manifold saying "POWER BLOCK" and the series (6-1 for example). John Deere blocks will have a casting number in raised letters on the bottom. Mike
J. Chantry
11-05-2007 19:04:33
I have a 6-2 powerblock in a 49 A. No petcocks
jd b puller
11-05-2007 19:01:54
Never seen a powerblock with petcocks unless someone added them.
Unless someone grinds the words off the top of it, it will also say "Power Block" across the top.
