53 JD 40T PTO oil seal
J. Chantry
11-05-2007 18:45:04
Currently restoring a 53 JD 40T, Serial #67588. The PTO oil seal needs replacement, Part #AM253T, but it is no longer available from JD. Is it available from someone else? Thanks for your help.
8e3k0
11-06-2007 09:42:38
 Re: 53 JD 40T PTO oil seal in reply to J. Chantry, 11-05-2007 18:45:04
National Seal number is 471192 and most bearing houses have lots in stock. Just purchased 6 last week at about $4 or $5 each. Same seals are used on the differential. Ellis
Mike M
11-06-2007 05:49:59
You should be able to have a bearing/seal dist. cross that number for you. Or if not measure the shaft and the housing bore and you can find one.
