1937 D - swap cast steel hub for steel wheel
Tony Flint
11-05-2007 16:26:48
Greetings!
Having to move a 1937 D that"s been sitting for years. Front rubber/spokes ok, but rear is another story. Cast steel hub with clamped rim, axle has two bolts holding plate on the end.
Rims are shot - non existent. Have rear steel available, flat spoke. Will have to count splines on the steel as the pics I have don"t show the center well enough.
Will these steel likely fit the axle, or are they too different? Flat spoke...
Tony Flint
11-06-2007 06:54:20
 Re: 1937 D - swap cast steel hub for steel wheel in reply to Tony Flint, 11-05-2007 16:26:48
Thanks all for the info!
Tony
Duane Larson
11-05-2007 20:18:30
Tony,
D's used 6 spline axles and wheels until late in the 1935 model year, when they changed to 12 spline axles and wheels. If you have/had 30" rear tires you likely need 12W x 30 wide-base rims, and 13W x 30 are available should you choose to go that route at some point. It's possible you have conventional 8.00T-28 rear rims - if so I would change out to 30" wide base rims. If you have Deere steel wheels, the only issue would be determining if they are 6 or 12 spline - if they are the correct spline they will fit.
jahaze
11-05-2007 17:24:12
My 37 D has flat spokes on the rear steel, so chances are if your wheels have the same number of splines as your axle, they should work.
