JD 2240 hydraulic sluggishness
Stonecreek
11-05-2007 09:36:38
I"m using a rather hefty shredder on this tractor, about 1500 lbs. Everything works fine for a little while until the tractor warms up, then the power lift gets very sluggish (slow to raise) and the PTO (independent) is very slow to engage (turns extremely slowly, then builds speed to normal). The PTO does not slip once engaged, but the power lift hardly works at all. This tractor sat up for a long time and the hydraulic oil was extremely dirty when I changed it (and the filter and cleaned the wire mesh screen.) Could the fresh oil have dislodged some additional sludge in only 15 hours of operation? Could that be clogging the filter or screen? Or do I have some more insidious problem? Thanks guys!
Tx Jim
11-09-2007 04:01:40
 Re: JD 2240 hydraulic sluggishness in reply to Iten, 11-05-2007 09:36:38
It's possible you have a leak there but the brake band could be worn out also. If I were you I'd do a pressure check. Tx Jim
Tx Jim
11-08-2007 04:29:11
 Re: JD 2240 hydraulic sluggishness in reply to Bob, 11-05-2007 09:36:38
Stonecreek,I'm not trying to dispute you but I checked JDParts dot com and I don't see a listing for manual steering on either SN's for a 2240. Was your tractor built for USA sales? Tx Jim
Stonecreek
11-08-2007 08:32:23
 Re: JD 2240 hydraulic sluggishness in reply to Tx Jim, 11-08-2007 04:29:11
I don't know the tractor's history, but it definately has manual steering (as the growning size of my biceps can attest). Both manual and power steering is shown in the Technical Manual.
Tx Jim
11-08-2007 03:51:19
 Re: JD 2240 hydraulic sluggishness in reply to MEANJDK, 11-05-2007 09:36:38
Stonecreek there are a line that feeds the pto clutch and a line that feeds the pto brake. These have been known to crack and leak. There are ports under the trans top(tin) cover where one can check pressure for each function. Memory tells me 175 psi is correct but I have no tech manual for said tractor. I've never seen a 2240 with manual steering either. If 3pt doesn't settle very quickly then that's probably not where your problem lies. Closed-center hyd's you'll learn to luv um or hate um. Tx Jim
Stonecreek
11-08-2007 17:02:27
 Re: JD 2240 hydraulic sluggishness in reply to Tx Jim, 11-08-2007 03:51:19
TXJIM, There appears to be no PTO braking action at all, so I'm wondering if the leak might be in that line?
Tx Jim
11-06-2007 04:40:08
 Re: JD 2240 hydraulic sluggishness in reply to Brianderry, 11-05-2007 09:36:38
Stonecreek your explanation of "works good till for a little while till oil warms up" is typical of the closed-center hyd system with an internal hyd. leak. Most likey if not equipped with a FEL with an ind. valve then your leak is in rockshaft valves,steering or the tubes going to the ind pto that have been known to crack. Tx Jim
Stonecreek
11-07-2007 14:25:39
 Re: JD 2240 hydraulic sluggishness in reply to Tx Jim, 11-06-2007 04:40:08
TX Jim, Thanks for the comments.
The tractor is not equipped with power steering, so that shouldn't be a factor. As I understand your explanation, there might be an internal (within the transmission) line with a crack. Would you remove the rockshaft assembly to inspect? By the way, the power lift seems to hold tight as a jug when left raised for extended periods, even under load of an implement - for example, parked overnight with the shredder raised. And the PTO, once engaged, seems to be strong - for example, strong enough to bog down the engine if you hit a stump with the shredder.
rexhellwig
11-07-2007 17:10:52
 Re: JD 2240 hydraulic sluggishness in reply to Stonecreek, 11-07-2007 14:25:39
I've never even heard of a 2240 without power steering.
machinery-man
11-05-2007 10:56:34
 Re: JD 2240 hydraulic sluggishness in reply to Stonecreek, 11-05-2007 09:36:38
I'd go with cleaning again...you probably aggitated all the debrie by now...It would be nice if you could flush the cavity of the tractor...
Stonecreek
11-05-2007 11:53:59
 Re: JD 2240 hydraulic sluggishness in reply to machinery-man, 11-05-2007 10:56:34
Thanks, I'll try a new filter first since that would be the easiest "fix" if that's the trouble.
JDknut
11-06-2007 04:22:56
 Re: JD 2240 hydraulic sluggishness in reply to Stonecreek, 11-05-2007 11:53:59
I'd change the hydraulic fluid again, too, as well as the filter. If it was that dirty before, you probably flushed loose more dirt after you changed the fluid, so you'll probably find this fluid to be dirty, too. You might be able to flush it some after draining, pour in some fluid while the drain plugs are out and you have a clean pan, see if any more dirt comes out. I did that with my 2350 MFWD, chased out some more crud that way.
