1932 GP Spark
Hotflashjr
11-05-2007 05:12:24
Went to help start my girlfriends father's 1932 GP this weekend. After turning the flywheel, then pulling it with the other GP, no luck. Checked for spark at the plugs and nothing. Took of the mag cover, spun her over, and there was good spark there. Used a little emery cloth on the points and checked the gap. Everything seemed good. Again, no spark at the plugs. Plug wires are only about two years old and the tractor is always kept under a lean-to. It has been about a year since it has been started. Any ideas? Thanks!
Chooch
11-05-2007 06:24:44
 Re: 1932 GP Spark in reply to Hotflashjr, 11-05-2007 05:12:24
Hotflashjr,
I think your problem is most likely with the mag. However, I would start by replacing the spark plug wires from the "32 GP with the ones from the other GP in which you know are good. Then see if you get any spark. If not, you may try removing the cap from the mag and cleaning the contacts again. Any amount of the white flaky substance can prevent it from firing. Reassemble and try again. If still no spark, there are a couple of other things you might try but it would be easier to explain over the phone. You can call me at (812) 259-1706. By the way, where are you located?
Hotflashjr
11-05-2007 05:45:59
We did put new plugs in and still no spark at the plug itself. We checked the wires over also for any little slits in the jacket and there was nothing. Any thoughts about the issue being with the rotor??
ET
11-05-2007 05:17:13
Did you try a fresh spark plug?
