Sounds like you have a problem there. LOL So... are those plug wires you installed a solid metallic core, or are they automotive resistor style wires? These old tractors need copper core wires to be able to make the most of the spark they produce. You performed a fairly good test by pulling plug wires. If in fact you are getting 94 PSI compression on both sides I think you are OK mechanically speaking. I dont think it is fuel related. Just set that carb at the reccommended setting. Your tractor will start and run pretty well there. It is a common misconception that a "hotter" plug has a bigger spark than a plug of a lower heat range. That is of course a falacy. The heat range of a plug is simply the temperature of the electrode. A hotter electrode will burn off excess deposits on the plug. They are used for applications where oil is being burned, or are sometimes used when a tractor is idled for long periods of time. A working tractor does not need a hot heat range plug because it is making enough heat during combustion to keep the plugs clean. A hot plug will actually cause engine temperatures to rise if a tractor is worked hard. My late B, when pulled hard, will have about a 5-10 degree difference with old D16 Champions vs. D21 Champions. My advice to get your tractor going is to go get yourself a known good plug and gap it open to 1/4 or so. Stick it on the wire of the cylinder that you think is not firing. Start the tractor, then take a pair of pliers to hold the plug and ground out the end against the chassis of the tractor. Did the spark jump with a white or blue color? If not you know your problem is up stream from the plug. If the spark is strong you need to take out those plugs you bought and toss them over your left shoulder into the junk pile. I've had fairly good luck using Autolite 386 plugs. They seem to last better than the Champions I've gotten previously. Gap those new plugs to somewhere around .030 and try it again. If you have good spark and new plugs you have eliminated your ignition system. If you do have problems up stream of the plug post back for more info. If your ignition system test out good you should look at your air intake system. Disconnect the breather from the carb. Is the choke opening all the way when commanded? If so start your tractor and take it for a small spin with the intake pipe disconnected. Did it run better? If so you have a blockage causing not enough air to enter you engine. I say this because the compression was maybe just a little low. Did you have your choke and throttle wide open for the test? If not that would certainly skew your reading. Just print this off and take it to the shop with you. What I've said may not be your problem, but it may spark the idea of what is the problem if you'll scratch your noodle and do some thinking. The best of luck!
