7520 JD
Greasey Hand
11-03-2007 18:20:19
Whats the HP? I was told 175 from the factory but that they were under rated & they put out 225 HP. Is this true?
Some have 30.5 X 32 Tires some 18.4 X 43 & others Have 20.8 Could they be ordered in diff sizes? What size plow, Disk, Digger, Chisel plow will it pull.
yello fello
11-04-2007 19:36:22
 Re: 7520 JD in reply to Greasey Hand, 11-03-2007 18:20:19
[quote
i use a j.d. 235 wing fold disc with cone blades, it works great in corn stalks =greasey Hand"](reply to post at 19:03:06 11/04/07) [/quote]
jdjerry
11-03-2007 20:18:02
I have one that the mechanic had on the dyno and shut it off at 235 hp and he did not have a load on it yet. He set the pump to factory specs and it is putting out 202 hp now. I pull a 35 foot chisel plow with it in 5th gear in low range. It will pull it in 6th gear but the pyrometer go up to 1200 degrees on the hills It has 30.5X32 tires and they were availible in different sizes.
Greasey Hand
11-04-2007 05:49:42
 Re: 7520 JD in reply to jdjerry, 11-03-2007 20:18:02
jdjerry
Im in MN. we use chisel plows in the fall.
In bean ground & corn they go deep & really rip the ground up, In the spring we use a digger a much less aggresive piece of equipment it would have a harrow to level out the ground behind it.
Then they plant. Are you talking about what we call a digger?
I dont think it would be what we call a chisel plow That would be to big for that tractor I think.
Have you ever plowed with it?
How many bottoms would it pull, 16" 18"
I was told they are under rated on the HP.
How do you like yours?
jdjerry
11-04-2007 19:04:55
 Re: 7520 JD in reply to Greasey Hand, 11-04-2007 05:49:42
I am talking a 1610 John Deere digger. I broke some praire with a 6-16 plow a few years ago. That was enough to make it spin on the grass. It pulls good but is dusty and noisy in the cab.
John Jenkins
11-04-2007 08:31:26
I think what he�s referring to is a 35� field cultivator. To put it in perspective, we had an 8630 that would pull a 36� pull-type field cultivator or a 16� 3-point hitch mounted chisel plow on mixed but mostly clay soybean land. I would guess that your 7520 in good tune would pull a 14�-16� chisel depending on soil type.
Greasey Hand
11-04-2007 10:03:06
 Re: 7520 JD in reply to John Jenkins, 11-04-2007 08:31:26
Just trying to find out what you guys would use for a disk on corn ground in the fall, Or a chisel plow.
Want somthing that does a good job, There are lots of different brands & types, Dont know whats the best & how many Ft wide. thanks
ram ranch
11-04-2007 19:14:53
 Re: 7520 JD in reply to Greasey Hand, 11-04-2007 10:03:06
I like to use a 30 foot Great Plains Turbo-till on corn stalks in the fall behind a 4955. Great seed bed for no-tilling beans in the spring with a 1560 drill.
