B DLTX 34 CARB.
JIMHAT
11-03-2007 15:58:23
I CAN NOT GET THE BOWL THAT HOLDS THE FLOAT OFF, IT IS LOOSE AND WILL TURN BUT NOT COME OFF. BESIDES THE LARGE NUT THAT HOLDS IT ON, AM I NOT SEEING WHAT IS HOLDING IT ?????
James Borders
11-04-2007 12:44:24
 Re: B DLTX 34 CARB. in reply to JIMHAT, 11-03-2007 15:58:23
The coil spring only holds the nozzle up in place. The nozzle is supposed to slide in but will prob need some coaxing to remove.
JIMHAT
11-03-2007 18:38:02
THANKS I WILL TRY KNOCKING IT LOOSE TOMORROW..
Andy Motteberg
11-03-2007 18:15:16
Like Maark said, the small bowl gasket might be stuck. If it is, pry or break it off.
Maark
11-03-2007 17:57:20
There is a gasket under that nut. it may be hanging up there. If you have the nut off, a few gentle taps with a wooden block on the carb bowl should knock it off.
JIMHAT
11-04-2007 12:19:15
 Re: B DLTX 34 CARB. in reply to Maark, 11-03-2007 17:57:20
YOU WERE RIGHT IT WAS THE GASKET... I HAVE ANOTHER QUESTION, WHEN YOU TAKE THE LARGE BOWL OFF.THERE IS A SPRING AND LOOKS LIKE A OPEN "PIPE" BOOK CALLS IT A NOZZEL, THER MUST BE SOMETHING THE SPRING WORKS ???? I WOULD LIKE TO TALK WITH YOU ON THE PHONE ?? MY NUMBER IS 325-854-1274, JIM HATCHETT, BAIRD, TEXAS THANKS
RobMD
11-03-2007 17:15:26
the large nut is the only thing that's holding it on.
