'48 B; Still more questions
C DC
11-03-2007 07:36:45
Thank you Mike,Frank,John,Pat and others for your input so far. As I am new to this, your help is invaluable.
Mike - I found the right marking on the carb., and it is a DLTX-67.
Pat - I will be ordering manuals this weekend, thanks again for the info.
All - I scrounged up a 12v battery to use for now to start the B when I need to, but I will be looking for the correct 6v generator and convert it back to 6v.
Now for a couple of new questions.
1. Is there a dipstick? How do I know the oil level?
2. I did drive it some the other night. (first time ever driving one of these things for me) As I was driving it back into the garage, I noticed the clutch/brake pad assembly (the one on the outside,that stops the drum from turning, I don"t know what you call it)was riding up and out of where it supposed to be, so that the pad was useless. It had walked up and over the drum. (luckily, I was just creeping along in 1st and the B just rolled to a stop) I"m sure there is a pin or screw that it supposed to keep that assembly in place. Where would it be? What would I be looking for?
Mike M
11-03-2007 15:18:29
 Re: '48 B; Still more questions in reply to C DC, 11-03-2007 07:36:45
The oil level is under the belt pulley area looks like a long hex nut with a bolt in it. 3/4" wrench size. loosen the outer bolt part some and if full oil will run out. If overfull or mixed with gas it will run out too so it may be good to catch it and see how overfull it is. If low just add til it runs out. Filler is large round pipe cap around top of belt pulley area.
Most of those pulley brake arms are really sloppy,new ones aren't totally tight either sometimes they need rebushed and shimmed to where they need to be. DON'T use it to stop the tractor that is what the foot brakes are for. The pulley brake is to stop the pulley for shifting gears or when you run something off the flat belt and need to get it stopped.Best to let belted implements coast down on it's own if you can.
C DC
11-03-2007 17:13:31
 Re: '48 B; Still more questions in reply to Mike M, 11-03-2007 15:18:29
OK. Thanks Mike.
