52 Model B
Ron Taylor
11-02-2007 20:34:13
I"m not too familiar with the 52,did they have 12 or 6 volt system?It has the Wico X so didn"t want to burn it up.Haven"t tryed to start it yet & need to know.Thanks
Andy Motteberg
11-03-2007 18:58:19
 Re: 52 Model B in reply to Ron Taylor, 11-02-2007 20:34:13
It should be 6 volts, I think.
It should have a distributor ignition, magneto was a option on late models.
wilamayb
11-03-2007 06:58:32
Ron make sure that your distributor/mag does not say Wico XB if so it is a distributor, not a mag. If you do in fact have a XB it should be on 6V for a B. I say this because most late B tractors came with XB distributors. Many have been changed out with a Delco distributor because of durabilty and parts prices, while some have been changed to a mag.
All this said... It is possible that your tractor did come with an X mag. It should be easy to tell which you have. A mag should snap and a distributor will not. A mag does not need external power wile a distributor needs battery power.
Ron Taylor
11-03-2007 19:30:24
 Re: 52 Model B in reply to wilamayb, 11-03-2007 06:58:32
Thanks guys for the info on the 52 B.I was wrong,it has an XB distributor.I didn't want to burn it up.Just wasn't sure if it was 6 or 12 volt.Ron
RobMD
11-02-2007 21:06:57
It should be a 6 volt positive ground, THAT IS, if your tractor has not been switched over to a 12 volt (look for 12 volt generator or an obvious alternator)
DanL-Colorado B36320
11-03-2007 06:06:14
 Re: 52 Model B in reply to RobMD, 11-02-2007 21:06:57
A magneto does doesn't care whether you have a 6V or a 12V system, because provides its own power and does NOT require a connection to a battery or any other power souce. To do so will probably burn it out.
