301A tractor with bucket
Greg Skirpan
11-01-2007 19:57:36
I will be looking at a JD 301A with a front end loader and 3 point hitch. It has a shuttle shift transmission. Are these good transmissions? Is there any common problem with these tractors I should watch for?
Wilsonfire
11-03-2007 10:19:00
 Re: 301A tractor with bucket in reply to Greg Skirpan, 11-01-2007 19:57:36
I can"t get a grease gun over the zerk on my axle shaft so I wrongly assumed it was a "bleed" point. Is there a trick to this and how much grease to apply? Thanx in advance for your help.
Roy Suomi
11-02-2007 19:29:10
301 is a dandy tractor...Only problem is they"re a little light in horsepower..The shuttle shift transmission is the same as in a backhoe..they are usually bullet proof.. Check the oil for discoloration..Offer to change the transmission filter for free..Cut the old one apart to check for metallic or "sparkly" particles..This would indicate either a maintenance problem or a potential failure..See if it shifts from forward to reverse without slipping excessivly..Jack up the rear end and push in on the rear tires to check for looseness in the rear axle bearings..The axle bearings are greasable but , seldom are..The fittings or plugs for the fittings are located between the fender and wheel on top of the axle housing..Out of sight ....Out of mind.....
