520 lopes at idle
Eldon (WA)
11-01-2007 08:43:59
It pulls good under load, but drives me crazy sitting at idle. The governor seems to be overcompensating....governor problem or carb problem?
jeep65
11-02-2007 16:38:52
 Re: 520 lopes at idle in reply to Eldon (WA), 11-01-2007 08:43:59
My 520 idled kinda that way when I bought it. I rebuilt the carb, I think the reason mine was idling that way was the throttle bushing and shaft were worn bad.
Don
WTW
11-01-2007 10:27:16
Eldon, Problem could be caused by either. A quick way to determine if it is carburetor or governor is let tractor idle where problem is present, hold arm on carburetor in a slow idle mode to keep governor from hunting. If tractor engine proceeds to die the problem is carburetor related, most likely restricted idle circuits. If tractor will idle slow while hold throttle arm from surging the problem is governor or linkage related. If it is like most with this problem you will find that carburer idle circuit restriction is your culprit. Good luck, DW
dfyyt
11-01-2007 09:39:27
Check the linkage... according to your manual (if you have one)
