Convert to hi flow hydraulics
csharney
11-01-2007 06:42:07
I have a John deere 250 skid steer. Can I convert this to Hi Flow Hydraulics?
Jonathan in mA
11-01-2007 13:17:25
 Re: Convert to hi flow hydraulics in reply to csharney, 11-01-2007 06:42:07
The high-flow on those has an extra pump bolted to the auxiliary drive on the engine...as well as a solenoid valve, switch and relay, and the needed hoses . Should be possible with some money.. No kit available..would need to be individual parts. I believe there were two wiring harnesses available on those.. The basic one (no cab or heat --just a bare-bones machine) might not have the wiring in the harness..You"d have to remove the overhead monitor panel and see if there is a switch harness connector hanging back there. It may very well be there already though.
