I agree with the good Marine man (My one sons a Marine, Always Faithful). First you gotta have hot battery voltage getting to the gauges input when the switch is on, you can easily test that with a simple 6/12 volt DC test light. Then as he indicated if you dead ground the gauges other output (to sender) terminal it should fully deflect UNLESS the gauge is bad (open coil or mechanically stuck needle). Note I said to ground the gauges output terminal to test the gauge instead of the wire on the sender just in case that wire is bad/open. To work the gauge needs hot battery voltage on its input,,,,, ,, It has to have continuity in its coil/winding,,,,, ,,,,,The needle cant be rusted corroded n stuck (can happen if water gets inside),,,,, ,,,,, then the output needs a return current path to ground via the wire to the sender then the sender itself. Thats why one can test the gauge portion simply by dead grounding its output which (if gauge is okay n not stuck) should cause needle deflection. Sooooo ooo test the gauge with battery voltage on its input (should appear when switch is on) and dead ground its output to see if it deflects????? ? If the gauge itslef is okay insure the wire down to the sender is okay cuz if so grounding it will also cause needle deflection. Finally if the gauge is okay and the wire to the sender is okay, another common problem is the sender itself HAS A POOR OR MISSING GROUND !!!!! OR THE TANK ISNT WELL GROUNDED. Take a good ground jumper wire and attach it to a cleaned shiny portion of the senders top metallic case or the ground tab on the sender see if it works then??? If so get the sender top and/or the tank a good clean ground. IF IT STILL DONT WORK (yet gauge n wiring n grounds are all okay) the sender is bad/open n needs replaced. Other sender problems are the float has detached from the arm n cant ever raise to the full level n follow the gas..... ....it ALWAYS reads tank bottom empty. If the sender is okay but the floats detached sometimes one can jury rig fix a float on there Usual problesm I find are the sender and/or tank arent grounded and my next suspect is the sending unit is bad/open. Next common problem is the needle is stuck/rusted. My buddy Bob M over on IHC says to take a magnet n move it across the gauge face cuz if the needle isnt stuck it ought to follow the magnet. Anymore you need to know about gauges n senders???? Best Wishes John T
