JD 490 Corn Planter
Minnesotan H
10-31-2007 19:16:45
I recently purchased a 490 four row corn planter. I was in very good condition with little rust and was told it planted fine a few years ago. I am having some issues with the power lift and trip levers. When I am pulling the planter and pull the lever forward, nothing happens. I am new to the power lift thing. I am used to lifting a planter with the hydros in the cab of the tractor and watching the planter raise and lower. What should I be watching for to correct this problem?
Greasey Hand
11-04-2007 06:10:22
 Re: JD 490 Corn Planter in reply to Minnesotan H, 10-31-2007 19:16:45
The marker arms are automatic there is small chains that go to a bracket that bolts to your drawbar it has 2 springs on it this switches a locking device so the wright marker goes down when you turn around at the end rows.
As far as the lift for the planter there is a lock to hold it up so you can take your hyd cylinder off when not in use.
NW MO Poppers
11-01-2007 16:51:39
Minnesotan H,
if the trip lifting mechanism is anything like an old trip plow, then you just tug and then release. if you keep hold, it will "bounce" (go up and then go down. it is funny if you are watching someone do this who has never been around a trip machine, but not to the person you are laughing at. BTDT
Mike Aylward
11-01-2007 05:02:04
MH, is it possible the lift chains are latched on each row? The 490 lifts by using chains to each row unit and there is a latch for each of them on the rear frame. Perhaps yours are latched for transport. Mike
