Wow, The voltage dropping all the way down to zero ???..... Could be a battery problem. Id check the battery to insure theres electrolyte above all the plates and no cells have a gray or milky color. Next Id try to give it a good charge n see if it takes it and if so what happens after that?? You can have it load tested for free at many parts houses, try that also. Okay say the battery tests okay, if she still dont crank properly (and the engines NOT stuck or starter stuck/jammed) next Id remove, clean n wire brush, n reattach each n every battery n starter n ground cable and if the ground is to a thin or rusty or wimpy sheet metal seat/battery box, try to atatch it to a good clean solid heavier frame bolt n try it. If still no cranking, next thing Id suspect is EITHER the saddle switch has gone bad like Frank mentioned OR ELSE the starter post under that switch is burned n pitted n corroded n worn down. FINALLY if the battery is okay (but that drop to 0 volts dont sound good) and all the cables n connections n grounds are okay AND IF THE BATTERY VOLTAGE STILL DROPS DRASTICALLY when the starter is depessed I SUSPECT THE STARTER IS EITHER BAD (maybe a dragging armature if she draws high current) OR MECHANICALLY STUCK/JAMMED. Heres the deal, usually if allll the cables n connections are good and the battery is okay but she dont crank yet the battery dont drop much voltage, then I suspect more the starter switch or the post I mentioned above (yet it can still be starter problem like worn brushes etc) HOWEVER if the battery n cables are okay but when you try n start her the voltage drops drastically, then I finally suspect the starter (cuz the switch n post is okay otherwise no high current voltage dropping draw) and it may well be a dragging armature from worn bushings. SUMMARY: Check the battery (charge it also) n cables n connections n grounds first and then if needed check the saddle switch and the post under it but if all that is okay yet the voltage drops big time and the engines free and the starters not stuck, probably a bad starter..... Let us know, you may just have a bad battery or it needs a charge or theres a bad or loose cable TRY EASY CHEAP SIMPLE THINGS FIRST John T
