JD 60 questions
Richiewis
10-31-2007 18:38:33
Going to look at a JD-60 WFE,PS,New Idea all hydraulic loader this weekend.What would be some important things to look at ? Believe it is a 1952,back tires are good,fronts bad.Supposedly used very little in the last 10 years.Any advice would be appreciated. Thnks
Jim/Iowa
11-02-2007 12:04:45
 Re: JD 60 questions in reply to Richiewis, 10-31-2007 18:38:33
For $4K, it should have:
Intact PTO shield, and in place
Clamshell fenders
All lights , including rear light, correct, present and working
straight, no ding, no dent sheet metal
Correct gauges, including tach, all working
Fresh and professional paint, quality decals
NEW TIRES, 13.6x38 on rear.
Mounting step
800 hitch, complete, and working
Full set of hydraulic plugs for powrtrol
Original owners manual and parts catalog.
It should NOT have aftermarket powersteering
There should be reciepts for the parts used in the recent overhaul!
buickanddeere
11-02-2007 14:14:21
 Re: JD 60 questions in reply to Jim/Iowa, 11-02-2007 12:04:45
funny
Richiewis
11-02-2007 12:28:40
Thnks Jim,Jd70, & buickand deere for your replys and info
Richiewis
11-01-2007 15:41:26
Forgot to mention,JD 60 owner is asking $4k firm !
buickanddeere
11-01-2007 16:45:53
 Re: JD 60 questions in reply to Richiewis, 11-01-2007 15:41:26
Pulley cover, pto cover, fenders, front grill screens, medallion, or is the battery box bottom rotten? Does the pto gear box oil stink like transmission gear lube? I wouldn't pay $4000.00 unless she has been put on a pto dyno and worked hard for 15 minutes.
buickanddeere
11-01-2007 05:01:05
A 60 usually didn't have flywheel spline problems unless some shade tree mechanic was exceptional crude. The clutch drive disk splines on a 60 do tends to wear as much or more than any other two cylinder. A 1952 did not have factory power steering. That became optional late in the 1953 model year. Like any old machine. Who knows what adventures it has seen and who may have tinkered with it. Unless engine work was performed with new fasteners, proper machining and a experienced person using a torque wrench. A late A or 60 can seep coolant around the head gasket.
JOHN DEERE 70
11-01-2007 03:59:52
CHECK THE FLYWHEEL AND THE CLUTCH DRIVE FOR WEAR ON THE SPLINES FROM THEM BEING RUN LOOSE.IF THEY ARE LOOSE THEY SHOULD MAKE NOISE .SOME PEOPLE SAY IT IS A NOISEY CLUTCH PUT IT ISNT ALL THE TIME. PUT VISIALY CHECK SPLINES FOR PLAY.CHECK FOR LIVE PTO ,PS.
JOHN DEERE 70
11-01-2007 03:59:47
