Gator Owners - am i ^%$%^% on this one??
tstex
10-31-2007 16:45:56
Hey Guys,
Have a 1998 6X4 gator and while i was driving it after reaching operating temp., it all of a sudden started steaming from underneath and the heat-indicator light came on...what i thought was probably a nice size leak in the radiator hose, i was wrong. it turns out to be the gasket that attaches the water manifold, on the side of the exhaust pipe, is leaking where it attaches to the main body.
I called my JD guy, and he said you have to replace all three gaskets, remove the water pump and to do so, you have to pull the engine! ouch!
he also said you need to remove-reset the belt pulley and it requires a special tool...
Anyway, am i going to take the "big-banana" on this one??? Has anyone done this before and does the description i gave you "kind of sound correct?"
I have rebuilt the JD MT tractor, but mostly replaced things...i would appreciate your insight as to what type of skill-level this would require, any special tools/set-ups etc?
If i let the JD dealer do this, any thoughts on what the pricing should be? he said the gasket set was around $115.00, then there is the labor.
Thank you very much inadvance for your advice and experience on this topic.
Regards,
tstex
H
buickanddeere
11-01-2007 05:05:46
 Re: Gator Owners - am i ^%$%^% on this one?? in reply to tstex, 10-31-2007 16:45:56
It's time to take the clutches apart and clean then anyways. If you don't have the correct dry film, non graphite, non stick lube. It's better to run the clutch dry. There is a trend away from four wheelers, gators, mules etc. To the used Jap 4x4 mini trucks. Rain tight, heat, wipers, comfy seats, a real cargo box, optional AC & some have raised roofs . Price is ok too. Right hand drive makes for a nifty conversation piece too.
wilamayb
10-31-2007 17:58:20
I did a little looking... It looks like your parts man priced you a complete gasket kit which includes all kinds of junk that you dont need. I think you should be able to get out with $20.00 worth of gaskets.
As for the clutch... I'm not sure. I dont see any need for doing any work on it if you dont take it apart. I dont think you have any reason to take it apart. Usually the guys at the dealership I worked at would just remove the engine on the gators.... It's just easier than being bent over underneath the bed.
I'm certainly not saying you JD friend is wrong about the mechanics, but he missed it on the parts by a mile. Perhaps you should do a little more investigation. The guys over at the lawn mower board may be able to fill you in on the specifics of the gator.
tstex
11-01-2007 06:37:46
 Re: Gator Owners - am i ^%$%^% on this one?? in reply to wilamayb, 10-31-2007 17:58:20
Thanks - where is the lawnmower forum? IS it under another name?
Thanks again,
tstex
RobMD
10-31-2007 16:50:06
115 bucks for a few gaskets?
I'd junk it
tstex
10-31-2007 17:04:21
 Re: Gator Owners - am i ^%$%^% on this one?? in reply to RobMD, 10-31-2007 16:50:06
my alternative is to spend at least 7 grand to get a used one...junking is not even a remote option.
RobMD
10-31-2007 17:42:33
 Re: Gator Owners - am i ^%$%^% on this one?? in reply to tstex, 10-31-2007 17:04:21
Yeah, but that's just what I would feel like doing, junking it. lol.
i recall a friend had his water manifold thing off once to replace a gasket, but I DON'T recall him removing the engine for JUST that...
